Old 06-18-2013, 04:13 PM
Adam's Avatar
Adam Adam is offline
1961 RCA 19" b/w with remote
It's the KCS 137 chassis, one of those series string sets with the weird tubes. It has not enough vert size, and nothing but snow and static when I hooked it up to the dvd player. 19AYP4 is pretty weak, 30/1000 on the old B&K 420, so if anyone has one let me know? The power tuning works, but the remote doesn't work at all. It's a mechanical one, until I saw this one I thought all the RCA remotes were electronic. It might be a while before I get to working one this one, but I think it's a cool set, the only 19" b/w RCA I've ever seen with the remote.
Old 06-18-2013, 04:57 PM
Rod Beauvex Rod Beauvex is offline
The lead ear.
Lovely set there.
I get -8 volts when subtract all the filament voltages from 120. Is this a design choice, the extra resistance is supposed to work, in conjunction with the caps, as a sort of regulation?
Old 06-18-2013, 05:36 PM
Adam's Avatar
I added them up to 115V? I pulled the sams folder, and it shows it adding up to 117V by counting the HO tube as dropping 19V instead of 17.
Old 06-18-2013, 07:50 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
That is a really thin plastic cabinet.
Old 06-18-2013, 08:45 PM
electroking's Avatar
a- v- karma member
Not so weird (450 ma series string) tubes, but note the Nuvistor (2CW4) in the tuner.
Interesting project for sure, hope you find the correct good CRT. Good luck!
P.S.: Also look at those four tubes on the lower left portion of the diagram: they
are for the remote control receiver, and have their own heater circuit!
Old 06-18-2013, 09:55 PM
zenith2134's Avatar
Really like that style of TV. Hope you find a fresh CRT
Old 06-18-2013, 09:56 PM
The lead ear.
Well, yes, they aren't listed in the diagram in picture four, and weren't counted.
Is rejuvinating the picture tube out of the question?
Old 06-19-2013, 02:01 AM
Adam's Avatar
It's odd that remote chassis uses a filament transformer, and the main chassis doesn't. There's also a single transistor in the remote receiver in addition to those 4 tubes.
I'm going to try rejuvenating it, but I've never had any luck rejuvenating tubes that were this weak to begin with.
I cleaned up the cabinet, this is a good looking tv, even if it's not working. I've always thought all the RCA sets labeled "new vista" (like this one) had the nuvistor tuner, but there may be exceptions?
Old 06-19-2013, 02:36 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
It uses a filament transformer so the remote receiver stays active when the set is off otherwise it would not work to turn the set on.
Old 06-19-2013, 02:40 AM
Also if there was a non-remote version it would be a pain to change the whole chassis heater wiring from version to version.
Old 06-19-2013, 02:08 PM
It's there, look for the 2CW4 tube in the tuner. Looks like a big transistor, about the size of a thimble.
Old 06-19-2013, 03:04 PM
Adam's Avatar
I was just wondering if RCA had ever used the new vista name on any sets that didn't use the nuvistors.
That makes sense that they would want the remote receiver to be on when the set was off, and they don't really have enough tubes in there to make another 117V series string. ... I never leave my remote sets on like that though, figuring it just wears out the tubes in the remote receiver faster.
Old 06-21-2013, 12:35 AM
OvenMaster's Avatar
DTV blows
I grew up with a set just like that one but it didn't have a remote... facing the front, the UHF tuner was on the lower right side where the remote circuitry is located on the OP's set. My guess is that you could have UHF or remote control but not both.
We owned it until ±1968, even after I tipped it and its stand over right onto its screen.
Tom
Old 06-21-2013, 01:12 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Now that's durability!
Imagine UHF channel surfing with a remote that has a single button for UHF tuning. Yikes! Actually saw that on an old Sharp remote.
Old 06-22-2013, 12:41 PM
peverett peverett is offline
I have three sets that appear to be very similar to ADAMs, but with the kcs138A chassis. Two of mine are restored and working, but one is a parts set. They use a 19AXP4 CRT. Luckily, the two that I have restored have pretty good CRTs. Not sure about the parts set. I have a RCA ad for these sets, the were called "Sportabouts" The different models available were the "Travel-mate", "Trimette" and the "Urbanite". The first two look like the set ADAM has. The "Urbanite" which looks different, was the most expensive model and I have it also. I had it working, but the horizontal has gone off frequency. As an example of the upgrades, the "Urbanite" has a power transformer and a 6BQ5 audio output. The others are series string sets with 6AQ5 audio outputs. The sound buzzes a lot as these warm up, so my wife call them the "buzzers".
Mine do not have remote controls.
