Old 01-10-2013, 06:39 PM
47'Plymouth 47'Plymouth is offline
Smile need a 25AP/XP22 Good CRT!
Hello All;
I'm looking for a good 25A/XP22...can ya'll spare one..to 29360...got a Maganvox color built in late 1960's...pickup at a loal thrift shop 2 years
ago for $5...found one of the CRT pins broken off..rendering it useless
thanks,Jody
Old 01-10-2013, 07:04 PM
Originally Posted by 47'Plymouth View Post
Hello All;
thanks,Jody
if you are carefull you can fix the broken off pin with a 300 watt solder gun even if the pin broke flush with the glass, ive done it, it works.
Old 01-10-2013, 09:50 PM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
I tried that with one of my Zenith sets, but couldn't get the solder to take hold. How did you get it to work?
Old 01-10-2013, 11:17 PM
colorfixer's Avatar
I put a "pogo pin" in the socket so that the spring loaded center pin of the pogo pin makes contact with the broken pin.
Old 01-10-2013, 11:51 PM
Conductive epoxy?
Old 01-11-2013, 10:50 AM
Originally Posted by Geoff Bourquin View Post
Conductive epoxy?
Except for the heater, pins on a CRT don't see much current, if any. So conductive epoxy should work. Mechanical considerations may pop up though.
Old 01-12-2013, 10:12 AM
Thanks Guys...
the original CRT is tested good but I have too admit i accidently broke the pin in question; slamm off even with back of the neck of the CRT...where can you obtain that epoxy form.that ya'll described to me..i found another tube that bursted lay on the side of the road in the trash with the same tube number and got the rest of the neck,electron gun...hoping i would salvage the pins...its was a Maganox also..the same age..I did get the old chassis,tuners,and a few other parts
for spares...but cabinet was shot! and tube was destroyed before i got there...
Jody
Old 01-12-2013, 01:06 PM
marty59's Avatar
marty59 marty59 is offline
I have a pulled (RCA) branded Magnavox 25XP22 that now tests great/uniform on all the guns after I did just one "clean" function with my Sencore. (All the guns were uniform but low to begin with and wouldn't track). It does have the typical cataract though. You can have it for the cost of shipping and work with me on the packaging.
You may be able to find one closer or repair what you have plus I'm planning on attending the ETF this year. There are options and these tubes are still out there for the looking.
PM me if need be!
Old 01-12-2013, 04:43 PM
ohohyodafarted's Avatar
Bob Galanter
Go to my web site (link below) I have a NEW, in the original carton Chanel Master 25Ap22. Look for the menu section Forsale/NOS Picture Tubes.
Contact me if you are interested.
ME http://AntiqueTvGuy.com
Old 01-12-2013, 10:56 PM
One idea, which you can probably find at a good auto parts store:
http://www.amazon.com/Permatex-21351...E?pageNumber=3
