Old 12-24-2012, 04:45 PM
What set does this knob this goes with ?
I've been sorting through some knobs and came across this odd looking one with channel #1. Any ideas ?
Old 12-24-2012, 05:05 PM
I have no idea what it's for but am wondering if that's the knob or the bezel?
It seems that another knob with a pointer might go inside it?
Or possibly it went behind a mask with a window so only one number at a time showed?
Old 12-24-2012, 06:25 PM
You're right, the hold through the center is smooth so a shaft could rotate through it.
Old 12-25-2012, 12:28 AM
Tim's Avatar
Tim Tim is offline
Sparton Mirror in Lid 4900 or 4940. It rotates inside the large round windowed raised gold bezel. Here is a link to one on Chuck's site:
http://www.myvintagetv.com/sparton_4940.htm
Tim
Old 12-25-2012, 01:27 AM
Cool, mystery solved
Old 12-25-2012, 08:22 AM
Mal Fuller Mal Fuller is offline
The caption for the Sparton mirror-in-lid TV says it has a 12 channel tuner. the mystery item features numbers 1 through 13.
Old 12-25-2012, 07:33 PM
Also the numbers would be upside down with the channel window in that location.
I think the general idea is correct though, it was used in something like this, perhaps a different Sparton, one with the window on the bottom?
Old 12-26-2012, 08:40 PM
earlyfilm's Avatar
Eternal Member
[/url]
Bob,
Next time you are in the Early Television Museum, you might look at their 1949 Sparton:
http://www.earlytelevision.org/sparton_4951.html
Click on the image to enlarge, then click again and it will expand more. I believe that is your knob.
The FCC dropped channel 1 in 1948, but several sets still had the obsolete channel in 1949.
This could simply be an early production 1949 set.
I think that this knob rotated, but since it had to be aligned to the tuner shaft and the window, it was held in place with a spring clamp outside the plastic.
Old 01-06-2013, 12:12 PM
Kevin Kuehn's Avatar
Workin' Late Again
Here we go. Maybe you also have the missing channel knob that goes to this set?
http://www.ebay.com/itm/VINTAGE-MIRR...item4ac02facdc
Old 01-07-2013, 11:28 AM
Looks like this set has the outer part with the channel #s but they stuck a 'tone' knob in the center.
Wouldn't mind getting one someday, but this one is a little too rough and far away.
