Old 11-04-2012, 10:33 PM
rca2000's Avatar
rca2000 rca2000 is offline
Look CLOSELY at the name tag on this...
It says Westinghouse...AND has three little triangles, one each of RED, GREEN And BLUE! next to the name
Could this be color?? Or just B/W?
WAY too far away for me to even think about...and besides...if it IS on of the "long lost color sets" it should go to someone who can bring it back to life!!
http://www.ebay.com/itm/Vintage-West...item1c2ce86cc6
Old 11-04-2012, 10:43 PM
David Roper's Avatar
console lover
ISTR this question coming up once before. The set at auction is definitely not Westinghouse' color set of 1957.
tvontheporch.com
Old 11-05-2012, 12:04 AM
I think it's just a stylized W made from three triangles, they are Pastel Pink Yellow and Blue also, not the RGB you would expect to see on a Color set.
It would be worth the drive to N.J. to get one though.
Old 11-05-2012, 01:03 AM
The closeup of the logo also makes it easy to see that the CRT is a B&W one, with no shadow mask.
Old 11-05-2012, 12:40 PM
kx250rider's Avatar
REAL TVs have TUBES!
That almost got me, as the famed 22" color set has a similar cabinet, and the front mask & glass are nearly identical. And the color set has no markings on it indicating color, IIRC.
But I agree that this is not the set. The color set had the on-off-volume knob at the upper left corner, and 3 white auxiliary controls centered above the screen.
Charles
Old 11-05-2012, 01:03 PM
lnx64's Avatar
lnx64 lnx64 is offline
I thought I replied to this. Yes, that's a black and white set. I've never seen a color CRT shaped like that either before.
Old 11-05-2012, 01:53 PM
Now you have... this shows a 22EP22 CRT, Made by Westinghouse ca 1957:
Old 11-05-2012, 03:11 PM
Celt's Avatar
Celt Celt is offline
Peanut Head
B&W Westinghouse.
Old 11-05-2012, 03:35 PM
What was the deal on that funky CRT ? Was it just that Westinghouse couldn't pull it off ? No market ? Too hard to make ? Not any better/worse performance than RCA's roundie tubes ? This all may have been covered B4, but please enlighten me again...
Old 11-05-2012, 04:29 PM
Long pump cycle (Kellers book says 24 hours), low yield, difficult to build and Xray shielding problems I believe, were the major reasons that Westinghouse changed the set design to use a 21CYP22 in 1958. For the CYP sets, the HV was dropped from 25 kV down to 22 kV and the lead shielding on the inside of the cabinet was eliminated and they claimed higher brightness.
Old 11-06-2012, 12:18 AM
lnx64's Avatar
Wow, I am in shock, I've never seen anything like that before.
But that's basically the godfather to rectangular CRT's. Awesome.
Old 11-06-2012, 11:07 AM
AUdubon5425's Avatar
I wish I could read what's printed on the bottom left of the TV.
I have come across a half-dozen B&W Westinghouses from this era and none had a logo with three color triangles. Something they did for a brief time, or with a certain series?
Too bad this is in New Jersey or I'd go see it myself.
Old 11-06-2012, 11:15 AM
Here's the thread on the rectangular Westinghouse, some good shots of it operating here.
http://videokarma.org/showthread.php...r+westinghouse
Old 11-06-2012, 03:39 PM
truetone36's Avatar
electronics packrat
That logo is a stylized "W", I have a late 50's Westinghouse AM/FM table radio with that same badge on it.
Old 11-07-2012, 11:40 AM
kx250rider's Avatar
The one in Steve K's thread, is the one I rescued from the alley behind an old TV repair shop in Chatsworth, CA in 1985 or so. It's the only one I've seen in person, and it's one I regret having sold years ago, although the current owner is a legitimate collector, and I am happy he has it and is taking good care of it. Also I very much appreciate Steve's magnificent job at restoring it electronically, and keeping it all original and correct, in the process :-) .
Charles
