Old 09-30-2012, 02:12 AM
jmm83 jmm83 is offline
canon VR-HF800 vu meter is dim
LED VU meter is dim it used to be bright not that long ago
does any one know what the problem is
let me know thanks
Old 09-30-2012, 09:32 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Actually that's a fluorescent display tube "FDT" not "LED". Probably electrolytic capacitors in the power supply failing.
Old 10-02-2012, 03:45 AM
waltchan waltchan is offline
let me know thanks
Most likely the caps are failing in the power supply, but a weak STK regulator is also a possibility. I just sold a Canon VR-HF730A (almost similar to VR-HF800A) with a weak STK regulator that doesn't always stay on with display flickering.
