Old 08-31-2012, 04:59 PM
Vinn Vinn is offline
Question panel meter for sencore cr70 rejuvinator
hey, any one know of a good sub. for the meter on this beast.Mine has open winding, aka (no deflection, no workie).
thanks ahead of time,
vinn
Old 08-31-2012, 06:09 PM
bob91343 bob91343 is offline
Sencore is one of the worst units out there. Having said that, look carefully at the meter to see if you can ascertain its manufacturer. Also look closely at the terminations of the meter coil to see if it might be repairable by someone with good eyes, a steady hand, and the appropriate tools.
Having failed that, figure out the full scale sensitivity of the movement and try to replace it with a unit made by the same company. That way, maybe you can transfer the scale to the new meter.
I have a Sencore transistor tester and it's such a piece of junk I won't use it. Maybe you can use the meter from it.
