Old 08-25-2012, 06:43 PM
Outland Outland is offline
Strange Streaking On Trinitron
Hey guys,
Thought I would ask.
Thanks all.
Old 08-25-2012, 06:55 PM
lnx64's Avatar
lnx64 lnx64 is offline
My Samsung does this. I think it's just capacitors. But I'm sure someone will tell me no, it's the CRT.
Old 08-25-2012, 09:01 PM
It probably is capacitors. Most likely in the video circuit. Does it still do it with the color turned all the way down? If so, check caps and resistors in the chroma.
Old 08-26-2012, 12:54 AM
I have definitely seen similar problems when a CRT is bad, but you would also see other obvious signs of a weak CRT: Dim picture and/or poor color when the set is first turned on, etc.
Old 08-26-2012, 01:00 AM
I don't know if it's the CRT.
Old 08-26-2012, 06:10 PM
Turning down the color doesn't affect the streaks.
Old 08-26-2012, 06:32 PM
lnx64's Avatar
I'm sure this is a capacitor issue and not a CRT issue.. To be honest, it could even be a bad ground and bad source AV equipment. I had a cheap modulator do this.
