Old 08-24-2012, 03:03 AM
jmm83 jmm83 is offline
Mitsubishi HS-U70 Remote
Hi does anyone have a Mitsubishi HS-U70 Remote Control or knows if a different Mitsubishi remote will work with it
i think i need it to set the clock
Old 08-24-2012, 12:38 PM
technoman9's Avatar
technoman9 technoman9 is offline
Look into here: http://www.replacementremotes.com/st...keyword=HS-U70
I punched in HS-U70 and they claim that these are replacements. They look to be the right type since they match the late-80's style of the HS-U70. They may not be new or perfect condition but they certainly will do the job!
Old 08-24-2012, 08:44 PM
waltchan waltchan is offline
Did you fix the broken HS-U70, and what was the problem?
Old 08-24-2012, 09:57 PM
yes it needed a new belt i had one that fit out of an old vcr but i will be buying a kit & replacing all the belts & pinch roller
