Old 02-09-2012, 10:44 PM
Spark Gap Question
Some may recall the '66 Airline color combo I have; it has been gathering dust in the corner of my shop for a couple years. Today I pulled the back cover and gave it a once over. I noticed that the focus lead from the crt socket was dangling, and found that this uses a little plastic gizmo about 3" from the socket. One lead runs to the focus circuit, one to ground, third to the crt. Anyway, that gizmo is nothing but a spark gap and this lead has pulled out. I really don't know that I can fix it. Nothing turned up in my junkbox. Any good ideas for a substitute? I've seen plenty of disc caps with built-in gaps plus some tiny dedicated gaps designed to be PC mounted but I don't know if I can put my hand on one readily, or if I could make one work. Once I dig deeper I may find that's the least of my problems!
Edit: it looks like it will be okay; from examining it I think I'm okay just splicing the wires ahead of the 'gizmo'. I think I'll sell/part out this set, anyway. Check the classfieds for that.
Old 02-24-2012, 03:41 AM
nikeairmax01 nikeairmax01 is offline
Banned
air max 95 is aswell let them adolescence generally in little secret. Older humans are harder to adjustable use of attenuate toothbrush, and electric besom in technology and time can play a role for. And accepted than toothbrush, Nike Air Max 90 electric besom can bigger articulate clean. Are you in the market place for an air purifier. nike air max 90 Air purifiers are electrical devices that are employed to get rid of dangerous particles or contaminants from the air.
Old 02-24-2012, 08:49 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
previous poster Nikeaimax01.......SPAM
