Old 12-13-2011, 12:23 AM
This is sort of a flat panel....
I dug a Sony FDL380 out of my box of stuff to fix someday, and need a bit of help. This one needs the 2 surface mount transistors in the backlight inverter. The old ones got hot and shorted. Does anyone have a manual for this, and could I trouble someone to look up the part numbers for them? Any tips on that circuit would be appreciated too. With the transistors removed the set runs OK, except, of course, the screen is dark until I shine a flashlight into the back of the LCD. And yes, it needs to be recapped. The stench of leaky caps filled the shop when I heated the solder to take out the shorted transistors.
Thanks!
