Old 11-21-2011, 09:07 PM
Got in a KV-8000...
From '77. I know it ain't perzackly a primo set, kinda fugly, really, but its in reasonable shape, & bein' its a Trinitron, it still works perfectly. And I've not got a king's ransom in it, either. Also got in another one of those funky JC Penney 5" B/W TV/scope units...This one works, but need De-oxit, & a general cleaning. WHY do I LOVE these damthings so ?!?
Old 11-21-2011, 10:05 PM
Cool! those are fairly scarce, I do not have one....yet! I have always wondered if that set uses a CRT with directly heated cathodes (like the KV-5000) or indirectly heated cathodes (like the KV-9000). If the set has been unplugged for a while, how long does it take for the picture brightness to come up to near full when the set is plugged in and quickly turned on? Does the brightness come up quicker if the set has been off for a while (but plugged in) and then turned on?
Old 11-21-2011, 10:51 PM
Seems like it "Steams in" full bore right after its turned on...
Old 11-22-2011, 12:21 AM
Even if it is "dead cold" as in sitting unplugged for an hour or so before being turned on?
Old 11-22-2011, 10:36 AM
Yep.
Old 11-22-2011, 12:09 PM
Thanks!
Then the KV-8000 behaves like the KV-4000 and KV-5000 in that respect, and likely has low-power directly heated cathodes in the CRT! That makes sense because the KV-8000 is also designed to operate from a battery pack. As far as I know the KV-9000 never had a battery pack, and uses slower warm up higher power indirectly heated cathodes.
Somebody posted here that the CRT in the 8" S0ny monitor racks used indirectly heated cathodes, so possibly S0ny builds the tube both ways, depending on application.
Old 11-22-2011, 05:01 PM
rpm1200's Avatar
rpm1200 rpm1200 is offline
I can verify the KV-9000 has an instant-on circuit with no vacation switch. It's also AC-only, typical transformerless hot chassis power supply.
Old 11-22-2011, 05:13 PM
Well, that's cool...I NEVER plug ANY of my stuff in unless I'm wanting to actually use it...Had a direct lightning strike summer Y2K that took out my Yammy CA-2010, CT-1010, B&O TT, JRC NRD-535D shortwave set, & a MINT Panasonic CT-3311, so I kinda learnt my lesson the HARD way...
Old 11-22-2011, 05:49 PM
Ouch!
rpm1200 said:
"I can verify the KV-9000 has an instant-on circuit with no vacation switch."
Yes! The KV-9000 uses indirectly heated cathodes in the CRT, but if the set is plugged in the "instant on" circuit produces a quick turn-on of the CRT (several seconds) similar to that of the KV-4000 And KV-5000 series sets.
I just performed the "dead cold start" test on a 9000 that had been unplugged for a while and the CRT took 15 to 20 seconds to come up to a reasonable brightness. If the set is plugged in and turned off a faint glow can be seen from the heaters in the CRT.
Old 11-22-2011, 06:49 PM
Yeah, CT-3311s are seemingly a LOT more rare than their little bros, the CT-101. But only full bore, bull-goose Loony TV Nut like Yrs Trly wants BOTH the Smallest color CRT TV ever made, & the 2nd Smallest one, too.. (grin)
Old 11-22-2011, 09:57 PM
mpatoray's Avatar
mpatoray mpatoray is offline
I love my KV-8000, mine has been modified by "Videotek" to have BNC and EIAJ-8 A/V I/O. I also have the KV-9000 that has had the same done to it along with a honkin big isolation transformer in the bottom.... The tube on the 9000 is much weaker
Old 11-23-2011, 01:05 PM
kx250rider's Avatar
REAL TVs have TUBES!
Nice find! I wish I could find the BP-8 battery case for that set. Seen one on eBay, but they wouldn't sell the battery case without the TV, which happened to be NIB.
Charles
Old 11-25-2011, 04:32 AM
jhalphen's Avatar
jhalphen jhalphen is offline
Hi Guys,
Over here in Europe, Sony's PVM-9000 was a portable 8" PAL/SECAM color Monitor with a striking ressemblance to the KV-8000.
In its heyday, it was a favorite bring along field monitor for video field production when the director wanted something bigger than a 4" screen or the tiny JVC TM-P3 (3") to check color balance on a remote shoot.
Like the KV-8000, the PVM-9000 had a DC power input for un undertray filled with Ni-Cd batteries.
Best Regards
jhalphen
Paris/France
Old 11-30-2011, 11:40 AM
fujifrontier's Avatar
fujifrontier fujifrontier is offline
roundie not so n00b
Awww.. that's an adorable little set!
Originally Posted by TVTeufel
Another idea.....instead of expensive anti-psychotic drugs, let's provide schizophrenics with dummy bluetooth headsets. They'll easily blend into the crowd, although I suspect their "conversations" would be far more rational than those of the typical Wal-Mart shopper.
Ron
Old 11-30-2011, 12:35 PM
ctc17 ctc17 is offline
Im in the club! I found one in the garage yesterday. Works too, has some vertical issues but no big deal.
