Old 09-11-2011, 02:11 AM
cbenham's Avatar
cbenham cbenham is offline
RCA VICTOR 9PC41 Projection Set on the bay...
#250889243268 current price is $9.99 with over two days left to go.
This is a very nice looking cabinet and looks fairly clean in the back too. It is about 25 miles West of Altoona, Pa. 7 pictures.
The seller says it is missing two 5U4s. It is also missing the top of the HV cage and the back as well.
I have no connection with this auction but I do hope someone grabs it and saves it.
Cliff
Old 09-13-2011, 09:46 PM
earlyfilm's Avatar
Eternal Member
[QUOTE=cbenham;3013700]
/QUOTE]
Well, Cliff, your hopes came true.
I low-balled a snipe and got it and will be going up Sunday to pick it up!
I've wanted one of these babies since the mid-1950's when I first saw one.
I know that many of the early RCA sets were safer to transport with their CRT's removed. Does that same warning apply to this set?
If so, does anyone know where there is a picture tube install / removal download?
I've read the one in Sams, but would kinda like to see some pictures.
James.
Old 09-13-2011, 10:10 PM
Dave A's Avatar
Dave A Dave A is offline
Unless you plan to UPS this beast, removing the tube is not needed. It is small and locked tightly in the projection cylinder. Tube alignment in the cylinder is critical and best left alone until after restoration. Then you go down that endless road.
The big problem with this set is the condition of the mirror at the bottom of the cylinder. The chassis is superb with 5 IF's as I remember. That gives a great pix with loads of chroma crawl.
Old 09-13-2011, 11:53 PM
cbenham's Avatar
I fully agree with Dave, you don't need to remove the CRT to move it. The SAMS folder gives pretty good instructions for optical adjustment, but remember as with all instructions, you need to read them then try and see if they work the way they instruct. Usually a bit of reading between the lines helps.
Glad you finally got the set you wanted and I hope you have fun making it work.
Please keep us all appraised of your progress and throw in some pictures as you can.
Best Luck,
Cliff
Old 09-14-2011, 12:01 AM
Pielock373's Avatar
Pielock373 Pielock373 is offline
Congratulations on your purchase.
Steve P
Old 09-15-2011, 11:49 AM
DavGoodlin's Avatar
Motorola Minion
Good luck James!
I have a 9PC41 too. Some day I will restore it. I certainly have all the tubes, etc.
What a wild set!
dave 63
