Old 07-10-2011, 12:02 PM
tvcollector's Avatar
High pitch ring
I just inquired a Sylvania Set from 1981, I know, imported, and a bit more modern than most care for on here.. I noticed after powering on and about 10-15 seconds later the high pitch ringing gets much louder than normal coming from the HV section somewhere, when on a station with no reception, it goes away, when adjusting the brightness low, it gets louder.. Would anyone know if this is a issue?
Old 07-10-2011, 12:58 PM
It probably won't hurt anything. It's most likely a loose flyback core and you may be able to silence it by using some silicon to hold it in place. Just use caution when working around the flyback or yoke. There are voltages there that will get your attention. If this is an '81 model, it probably uses an E32 chassis. '81 was also the year that NAP bought the Sylvania and Philco names from GTE; so, you could have a "last gasp" GTE set or an "early" NAP set.
Old 07-10-2011, 01:46 PM
holmesuser01's Avatar
Sometimes re-flowing the solder on the pins on the flyback can help, if this is a chassis where the flyback is surface mounted on the PC board.
Old 07-10-2011, 02:05 PM
Here are some pictures.. It looks close to the mid 1980s Sylvania Super sets, I'm guessing an early NAP.. The flyback is mounted on the Board.. Does this hold voltage after being unplugged or is it only the picture tube?
Old 07-10-2011, 02:17 PM
sampson159's Avatar
sampson159
those are very good performers!solder joints around flyback or loose core.that will fix it up.sharp,sharp. black matrix crts produce a fine picture.among the best picture of all time
Old 07-10-2011, 02:22 PM
I notice it has a bit of a brown tint, more likely the red is a bit high, I've fixed issues like this before by adjusting the red, green and blue pot switches, But I don't know if I'm doing that to make up for week guns or bad circuits.. I could get my sencore out and test each gun..
I agree those early, mid 1980s super sets put off a great picture.. We had one in the family that was bought new back in 1985, it lasted till 1993 when the tuner went out..
Old 07-10-2011, 02:28 PM
Is that an old hospital set? Back in the '80's, the local hospital had some of these and they used a heavy 3-wire AC cord. There was a socket on the rear of the set for the remote pillow speaker and the TV's would also work with an IR remote.
Your chassis was actually a "transition" chassis. They came out while GTE still had Sylvania and they stayed around well into the NAP era. I used to have a 19" GTE-Philco from early '81 with this chassis. I tossed it when the CRT got too weak to use.
Old 07-10-2011, 02:45 PM
I don't think this set is, It doesn't have any socket to connect an IR Remote.. Would you recommend a discharge of the crt before going around the flyback area?
Old 07-10-2011, 03:24 PM
Tightening those two hex nuts a bit may quiet it down. Don't tighten too much 'cause that's a powdered iron core. oc(Bill)
Old 07-10-2011, 03:54 PM
take an insulated alignment tool and touch the ferite beads on diodes, resistors, etc. Something is vibrating. If you find a bead loose, use candle wax to secure it. RTV may trap moisture.
Old 07-10-2011, 04:03 PM
I re soldered and sanded all the joints to the flyback and still does it, I notice the brightness changes depending on the image that shows up on screen..
Old 07-10-2011, 04:18 PM
I just tightened two hex nuts and the set is much quieter now. I was only able to get a nudge, even doing that i heard a crunch noise..
Old 07-11-2011, 04:26 PM
I let the TV sit with the cover off and let it run for hours and hours and the symptoms all went away, TV must have been stored without use for a long time, I adjusted the red blue and green pot switches to normalize the colors, red having to turn down alot. after a few hours of running I had to turn the red back up, I think tells me the CRT cooked it's self back to life. I brought out my Sencore CR-70 and I'm looking in the 1992 CRT number listing booklet and the number of the tube is not listed, it's a MV19VLEP22...
Old 07-11-2011, 05:54 PM
Drop the MV prefix and look it up as a 19VLEP22.
Old 07-11-2011, 10:52 PM
mbates14 mbates14 is offline
caps could be starting to dry up as well.
