Old 04-24-2011, 09:20 PM
PioneerGuy75's Avatar
PioneerGuy75 PioneerGuy75 is offline
Pioneer Memeber
Question Samsung Parts?
I have a 27" Samsung Digital tube type TV (Easy Fit HD I think they called it...)
It has a bad power supply board. Where can I find a new one?
Many thanks!!
Old 04-24-2011, 09:50 PM
Samsungs actually have identifiable parts in them ? I thought they were all just "Black Majick" or Pixie Dust...
Old 04-24-2011, 11:08 PM
joemama99 joemama99 is offline
Take the number off the board and type it into an internet search-usually works for me.
Old 04-25-2011, 01:40 AM
bob91343 bob91343 is offline
Boards don't generally go bad. Components on them do. So troubleshoot it and repair it.
Old 04-25-2011, 10:14 AM
That would probably be the best action to take. The only time I replace boards is when the original board was severely damaged by lightning, has received severe physical damage, or uses extensive surface mounted components that would make the board impractical to repair with regular soldering equipment.
It's very likely that your board will only need a few low cost components; which, will be MUCH cheaper than a new board, if you can even get the board. When I first started repairing TV's, I'd often replace the whole board. Then, I discovered that I could often fix the old board with $2 worth of new parts. That sure beats $50-$100+ for a new board.
If you still feel like you need a new board; these folks, http://www.pts-electronics.com/home-page/, may have the board or can rebuild your old one.
Old 04-25-2011, 06:54 PM
Pioneer Memeber
Thanks for the advice
This is the first set in a LONG time I have thought to be worth fixing....This is why I was pondering replacing the board.
Cheers
Old 04-26-2011, 12:12 PM
usually it's the electrolytic caps that go bad. Hopefully no hard to identify or unobtanium semiconductors have gone bad.
Old 04-26-2011, 12:24 PM
JCFitz JCFitz is offline
If that set has the same separate power supply board that the larger Samsings had there was a high value resistor in the feedback circuit that changed value and caused excessive B+ and the X ray shut down activates when the set is turned on.
Old 05-15-2011, 05:16 PM
Pioneer Memeber
I have been through every board on this TV and cannot find anything wrong....I have re-soldered several joints (Did not look real bad, just wanted to touch em up)
No visibly bad components, signs of overheating or anything of the like...
When plugged in , the power light flashes six times and does not power up. According to Samsung website, this means it needs a new power supply. (Consumer website so no technical help.)
Can anybody help me diagnose this? Refer me to any websites with diagnostic help etc?
Any help much appreciated!!!
Model TXR3079WHX/XAA
Type CR32Z30
Chassis K62A
Old 05-16-2011, 09:13 PM
mbates14 mbates14 is offline
Type CR32Z30
Chassis K62A
Thats the same thing if you crank over your car and it dont start, you need a new engine.
You have to do more extensive troubleshooting.
Old 05-17-2011, 06:06 PM
holmesuser01's Avatar
Have you checked the horizontal output transistor? Is it shorted?
Old 05-17-2011, 07:53 PM
youmjutt youmjutt is offline
Banned
I have a Samsung U900 (Soul) in black that has an absolutely wrecked battery cover.
Does anyone know where I would be able to find one?
Old 05-18-2011, 11:25 PM
Pioneer Memeber
I understand. I am having difficulty with diagnosis as it will not even power up...
Does anybody know what the six flashes means?
Cheers
Old 03-25-2012, 08:35 PM
Pioneer Memeber
I am revisiting this old thread and TV again...
I have gone over the power supply board with a fine tooth comb and cannot find anything that looks wrong. All solder joints look good, no components look burnt etc.
I would like to seek assistance in diagnosing this problem please.
TV does not power on, the red light flashes six times is all.
Thanks for any advice!
Old 03-25-2012, 09:01 PM
eBay has a zillion Samsung Power Supplies, most of them are for Flat Screens though.
It might be helpful if you could post the model number of your set and maybe a picture of the PS.
