Old 04-06-2011, 03:47 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Soviet TV on ebay!
I bid, but I'm not the high bidder.....someone wants it more than me
http://cgi.ebay.com/Russian-Portable...item53e6e9eca9
How cool!
Old 04-06-2011, 03:52 PM
jbivy jbivy is offline
complete novice
Wow, thats interesting. I wonder what the chassis is like?
What voltage do the russians run on?
"Good morning whiskey, good morning night. The end of the world is in my sight." Hank 3
Old 04-06-2011, 06:18 PM
electroking's Avatar
a- v- karma member
Funny brand Yunost, litterally means 'youth' :
http://en.wikipedia.org/wiki/Youth_(Tolstoy_novel)
I don't think I have seen another Soviet TV offered by a U.S. seller...
P.S. : link will work when you add ) at the end. Sorry about this.
Old 04-06-2011, 08:20 PM
ctc17 ctc17 is offline
Is this 240 volt 50 hz SECAM? How would this work here in NTSC land?
Old 04-06-2011, 08:35 PM
If it's B&W, just set your DVD player to "PAL" mode. That will put the deflection rates that will match what SECAM used. But you need a special TV modulator that can get the signal onto a channel this set can tune, and more significantly, the FM sound subcarrier is something different than the American 4.5MHz, 6.5MHz I think it may be. You might be able to hack an American mode TV modulator by changing the LC circuit for the sound subcarrier.
As for the power, 60Hz should be fine. An outlet like the below, 230VAC @20A and 60Hz would be what you'd want to install. Usually used for larger window air conditioners. Both sides of the American pair of 115VACs feed this kind of outlet, plus a safety ground. Here I installed this in the kitchen, and grabbed 230V off the electric heat circuit ahead of the thermostat (protected by a 20A breaker). Don't tell my landlord, but landlords never notice things like this (I did it neater and reasonably code compliant than their maintenance staff would have, and with 200 units in this 25 year old complex they won't remember that it wasn't there before, and some units were recently redecorated so the units already look different from each other anyway), but they do notice things like dirty bathrooms when time comes to move out.
So now I can power my various Australian and European radios, which are perfectly happy with 60Hz. Their 50Hz power transformers run cooler on 60Hz.
Old 04-07-2011, 09:39 PM
Well I own it. I kinda forgot I put a late night half asleep bid on it last week. Well it will make for some good pictures to post.
My video card will do composite SECAM but I would need to do a direct injection or come up with some kind of modulator.
Old 04-07-2011, 10:00 PM
Great ! Glad "One of Us" got it...
Old 04-07-2011, 10:56 PM
maxhifi's Avatar
maxhifi maxhifi is offline
CTC17
Congratulations - I've wanted a Soviet TV for a while, but will probably hold out for a tube model (they made all tube B&W t's well into the late 80s)
Here's some info on it, it's solid state and from 1974.
http://rw6ase.narod.ru/000/tw/junost401.html
Also, attached is the original data sheet, for those unable to read the links on above webpage.
The schematic is here
http://www.rw6ase-dok1.narod.ru/arhiv/junost401sx.djvu
You will need the deja vu plugin for your browser
Above website contains a catalogue of almost all the consumer electronics made in the USSR. I was looking at it for hours when I first discovered it. I've got a couple radios, and a tube record player from the USSR. If you need help getting parts like transistors, send me a PM, I know a guy who is able to get this kind of stuff, I've used him a couple times in the past for misc. soviet parts. Some of their full range speakers are fun to play with in small arrays, and I bought a pile of spare needles for the record player.
Old 04-07-2011, 11:04 PM
Wow cool! thanks for posting that. I thought this was a tube model, it will be cool to play with for sure.
Old 04-07-2011, 11:20 PM
maxhifi's Avatar
I wouldn't be too let down it's not tubes - their transistor stuff is just as weird. You'll see what I mean when it shows up and you get to take it apart, I have a feeling you won't regret spending money on it once you see how this stuff is built. The really neat thing about Soviet electronics is nearly every western country had trade a embargo against them, so pretty much every component is home grown, including all the semiconductors. Another cool thing is that since everything was made by the government, there are government standards which define how everything is made, and stuff like service info is now totally free of copyright and fairly well organized and comprehensive.
Old 04-08-2011, 12:06 AM
The perfect set to watch Trolololo on!
Old 04-08-2011, 01:53 AM
<Boris Badenov voice>
In Soviet Russia you don't watch TV, TV watches you!
Old 04-08-2011, 06:33 AM
Kamakiri's Avatar
English translation of the ad:
Movable television set of the 4th class of ' ' Youth -401' ' ([PT]-31-IV-1) it is intended for the method by the tele- the [vizionnykh] programs in mV, and with the installation of the selector of channels SKD -20 and in Moscow Standard Time range. Television set of ' ' Youth -401[D]' ' already has block SKD -20. Model ensures the steady method at a distance to 100 km from the television studio. In it [primenen] the kinescope of 31[LK]4[B], with the angle the slope [niya] of ray of 90°. In the diagram there are by ARU and APCh and [F]. [Chuvstvitelnost] TV 100 V, clearness 400 lines, the output power of 0,75 W, the band of frequencies 200… 7100 Hz. ACE consist of dynamics TI pA of 0,5[GD]-30, is a nest for the connection of head sets with turning off dynamics. Nourishment from network, storage battery, or any source [PT], with the stress of 12 volts. Consumed [moshch] [nost] with the nourishment from network 30, from the source of direct current 14 W. Case of model from [plas] [tmassy], it is finished by film under the valuable species of tree with the metallization. Overall sizes of the apparatus 376[kh]315[kh]260 mm. mass 10 kg. price - 280 rubles. As it was written in the advertisement: Television set ' ' Youth -401' ' - these are your reliable satellite and the friend of house, on leisure, in the marches and the expeditions
I've always wanted a soviet TV too.....the land of my ancestors
Old 04-08-2011, 09:57 AM
a- v- karma member
Interesting that such a modern TV would still be using a 90-degree CRT. I guess
this made it possible to save some power, a good feature in a portable unit
capable of running off a 12-V battery. The Russians (then and now) should not
be underestimated...
Old 04-08-2011, 10:07 AM
a- v- karma member
Interesting statement, but I'm not sure many (or even any) western
countries ever had an embargo against the USSR. If you have some
references regarding the history of this, I would like to see them. I trust
this discussion is not drifting too far way from the original topic.
By the way, the site mentioned elsewhere in this thread (rw6ase.narod.ru)
is chock full of nice pictures of old electronics. Be sure to have a look!
Regards to all.
