Old 03-13-2011, 08:12 PM
Zenith6S321's Avatar
Zenith6S321 Zenith6S321 is offline
Restore 21CT55 to schematic or as built?
This is my first post, but I have been reading posts for a bit. Great forums! I am starting the restoration of my RCA CTC2B 21CT55 chassis serial number B8802628. I bought it in the early 1970's and am finally going to attempt to restore it. I bought capacitors and resistors based on the Sams parts list. I started comparing the convergence chassis wiring against the Sams schematic and find missing/different components. I expect this is due to running production changes. Is it generally recommended to restore a chassis to as built or to the latest dated schematic? Anyone know if the Sams 21CT55 schematic represents the "first set" or "final set" design? Any guidance would be greatly appreciated.
Old 03-13-2011, 08:57 PM
I go with what I find in a TV, if it looks original. My theory is that it must have worked when it left the factory.
I would be especially cautious about changing components in the RF and IF sections.
Just my $0.02.
Old 03-13-2011, 10:02 PM
Old 03-13-2011, 10:06 PM
Steve K Steve K is offline
When I restored mine I went by the RCA manuals and schematics. I don't remember any differences. Remember, Sams often has mistakes. I'd be happy to look up something for you in my schematics or send you a copy if you would like.
Steve
Old 03-13-2011, 10:07 PM
Andy:
I didn't mean to repeat what you said, you posted as I was typing.
Steve
Old 03-13-2011, 10:25 PM
reeferman's Avatar
Stay as made. Rca built it, not Sams.
Old 03-13-2011, 10:36 PM
That all sounds like very good advice guys.
Phil, thank you very much for your excellent web site covering the CT100 and your restoration. I also had problems with intermittant loss of color synch in this CTC2B chassis, some 20+ years ago. Now that I can afford the proper test equipment I look forward to trying to track it down. Although the set displayed a very nice picture when last turned on 15+ years ago, it required lots of tweaking as it operated. The 21AXP22A and the flyback were replaced by the previous owner (TV repair shop manager).
Andy, Steve and Reeferman, thanks for the warning about Sams accuracy. At the least I will update my Sams schematic as I recap and verify resistances and check the coils for continuity (maybe I will also try to find an inductance meter).
Steve, I have searched the web for a copy of the RCA service manual/schematics to no avail (except for Sams). It would be very helpful if I could get a copy of any information you would be willing to share!
Old 03-13-2011, 11:34 PM
Ditto on Sams being prone to errors.
Bill(oc)
Old 03-13-2011, 11:43 PM
Welcome to VK! What part of the "free" state are you from? Very desirable set you have...you shouldn't have any trouble getting the answers you need on here.
Old 03-14-2011, 01:02 AM
Zen...
Send me a PM with your name and address and I will send you copies of the service info.
BTW, I pulled out the Sams and the convergence chassis is different from what is in the RCA schematics.
Steve
Old 03-14-2011, 07:34 PM
PM sent, thanks Steve!
Old 03-14-2011, 07:40 PM
Bryan, I'm located in southern MD a couple hours south of DC and Balt.
Old 03-14-2011, 09:30 PM
In a later post you say the flyback was replaced - this may have required changes to the convergence chassis if the replacement flyback's windings are different. So, another vote to stick with what is in the set instead of what's in SAMs.
Old 03-14-2011, 10:15 PM
Steve McVoy's Avatar
Zenith6S321, is this a set we have in our database? Could you send me a PM with your name and information on where the set came from?
Thanks.
Old 03-15-2011, 12:31 AM
If you find any good tricks, I'm all ears. I do need to revisit that issue. Just got distracted with some other projects while waiting for my brain to grow a couple more hat sizes
