Old 02-23-2011, 03:01 AM
miniman82's Avatar
First Light: 1952-2011
Admiral 30A1S in Hollywood
Like the one Bob has!
No affiliation
http://losangeles.craigslist.org/sfv...219037828.html
Evolution...
Old 02-23-2011, 03:35 PM
I think this blonde model is the least common of the early Admirals. I hope someone can save it.
I like the sellers attitude
More than money however, I want to insure that this television set goes with someone who will restore it or at least keep it from deteriorating, so it won't end up in a landfill, turned into an art deco aquarium, or being pieced out for spare parts.
Old 02-23-2011, 04:03 PM
miniman82's Avatar
Yep, don't see that too much these days.
Evolution...
Old 02-23-2011, 04:18 PM
Kevin Kuehn's Avatar
Workin' Late Again
Nice. Has anyone here successfully refinished a blond finish TV? Most of what appears to be wood grain on blond furniture of that era, is in fact a painted on faux finish.
Kevin
Old 02-24-2011, 10:32 AM
Kevin
I have three blond sets. One is made from Korina AKA Limba wood. The other two, including this set, are limed oak. There are some worn areas on mine so I can see the various layers. The cabinet is made from plywood with red oak veneer. Over that is a thin whitewash. Over that is a golden tinted lacquer.
Here's the Korina.
Here's a worn area on the limed oak.
I've done some experiments to replicate it. It's not quite right yet.
Old 02-24-2011, 01:34 PM
Workin' Late Again
Your blond samples look very promising. Possibly try a dark grain filler first? But I've seen the grain white as well.
The Admiral pictured below is an example of genuine blond painted Masonite, with real wood trim around the front. I guess they hadn't figured out how to make Masonite molding yet.
Old 02-24-2011, 02:59 PM
Here's a discussion on ARF with some good info: http://antiqueradios.com/forums/viewtopic.php?t=149113
I wonder if Eric had any luck with his cabinet
Old 02-24-2011, 03:26 PM
Workin' Late Again
I picked the Admiral up for $1 at a local auction. Was going to rob the CRT, but its so hard to part em' out.
Kevin
Old 02-24-2011, 05:16 PM
Has anyone tried applying watered down white(or some such) paint so that it lightly tints the wood? About 10 years ago in the house I grew up in my mom used this wierd technique to touch up the built in blond wood(pine) cabinets. After she was done the section she redid matched the original quite nicely. I believe she called the process pickleing, though I might be wrong.
