Old 01-06-2011, 03:22 PM
zapro zapro is offline
VK Member
Schematics for Philips Video 40 CCTV camera
Hello.
Do anyone have schematics for a Philips "Video 40" CCTV camera with a 1/2" Vidicon tube ?
I found some pics of one (the first three pics) http://picasaweb.google.com/AstroTas...58260120547554
Thanks in advance,
// Per.
Old 01-10-2011, 05:17 AM
VK Member
Update: I found a "real" model number of the camera.
It's called LDH 0400/01 / NC 8925 040 00101
220V AC 50 Hz 8,5W
I find it amazing that google cannot come up with a schematic or user manual, this is from Philips, they were a great brand back in those days.
A funny feature of it - in the back there is a adjuster knob that controls the movement of the whole vidicon assembly up in the front of the camera via a turning rod, quite ingenious.
// Per.
Old 01-10-2011, 06:23 PM
VK Member
Update 2:
Tried connecting my two Video 40's to my TV's CVBS input and a video capture card.
All i get i a grey screen.
Looking at the BNC connector, my cameras puts out this:
Waving my hand in front of the lens does change the video signal a bit on the scope, but still does not show up on a TV.
Something seems fishy! The sync is inverted ???
Maybe the output signal is not CCIR standard video ?
// Per.
Old 01-13-2011, 11:09 AM
Originally Posted by zapro View Post
Update 2:
// Per.
The sync and blanking is quite normal (negative sync on baseband video). "black" level should not be so high, and obviously you should have a much bigger peak-to-peak video swing.
Edit: do you have a lens on the camera? If not, the automatic gain will set the general video level to 50% as you see.
