Old 12-26-2010, 06:23 PM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
Quick Question: RCA 25XP22/AP22A. Black Matrix?
Tube is labeled "colorama", but is a rebuild. Want to install a good black matrix tube in my Zenith Emperor. Is this what I'll have? Hooking up the CRT tester now...
From Captain Video, 1/4/2007
Old 12-26-2010, 07:21 PM
Carmine's Avatar
CRT passes with flying colors (pun intended)
The Emperor is down! The Emperor is down!
Old 12-26-2010, 09:57 PM
miniman82's Avatar
First Light: 1952-2011
Your link is bogus, here:
Evolution...
Old 12-26-2010, 11:34 PM
I don't think so. I'm thinking all the black matrix tubes would have been from the 23V series. The 25XP/AP is an older type. You can usually tell from looking at the faceplate as the phosphor dots will be well defined with the set off. With the non-black matrix tube you really have to look close to see them.
Old 12-28-2010, 01:13 AM
Carmine's Avatar
That's what happens when you post from a phone I guess...
Old 12-28-2010, 01:16 AM
Carmine's Avatar
I think you are correct. I examined a chromacolor tube up close, and could see the black matrix. Just gray on the "colorama".
I was perhaps wishfully thinking that colorama was RCA's trade name for a black matrix tube.
Old 12-28-2010, 01:40 AM
ctc17 ctc17 is offline
Nope not matrix. That set should have a fairly good picture. What chassis is in it?
Between DaveWM and I we have around 10 of those vintage Zeniths. They very rarely need electrolytic caps. They always have one or two challenging problems that seem to center around HV regulation or Chroma. They flybacks are really robust in those sets.
I remember you saying this set worked and had a bad crt or something.
Old 12-28-2010, 02:10 AM
IIRC, "colorama" is RCA's designation for their rebuilt color CRT's. "Hi-Lite" is their line of new color CRT's.
Old 12-28-2010, 02:16 AM
Carmine's Avatar
I started a new thread for the CRT replacement (which now looks like it may come from a Chromacolor set that works well, but is in a "blah" cabinet).
Old 12-28-2010, 02:45 PM
sampson159's Avatar
sampson159
that rca crt will give you a good result.a zenith 23v from the chromacolor series would be the ideal swap.i havent seen one of these sets for years.there is one advertised on the etf site.it is in hilliard,ohio.i have tried to contact owner several times with no response.my zenith tuber has a sylvania black matrix crt.if this is a keeper set for you,i will try to locate a black matrix crt for you.good luck and i enjoy spaghetti too.
Old 12-28-2010, 05:32 PM
