Old 12-16-2010, 04:49 PM
rca2000's Avatar
rca2000 rca2000 is offline
Does ANYONE here have access to a panasonic eeprom correction jig??
I REALLY need access to the panasonic tool called the "eeprom correction tool".PT#LSUQ100. It is a small box that connects to a port on the light engine on the panasonic LCD RPTV sets. I USED to have access to one a couple of years ago, when I worked for the "cheaters", but I do not now--and panasonic does not make LCD projo sets anymore--so the place I work for does not have one . Hopefully--someone here does have one. This is my OWN set--PT44LCX65--and I like and use it a lot. The jig will work with MANY sets, not just one, and can be used over and over. Maybe someone here has--or knows someone else who does have--one I could rent, just for this set?? I have the "red spot" syndrome--about a 2" red spot near the top right hand corner--and it just happened ALL AT ONCE--today, I have fixed a LOT of these with this sort of problem in the past--now--I need to fix mine.
Anyone ?? Anyone??
