Old 09-09-2010, 09:03 PM
Dan Schafer's Avatar
Dan Schafer Dan Schafer is offline
Danny in Cleveland
YPbPr input trouble
Hi All,
Just bought a new Westinghouse 26" model SK-26H640G. I have a Toshiba DVR model D-R410KU that has YPbPr outputs. The new TV is a cheap-O with not enough inputs & I need to use the YPbPr input on the TV. Hooked-up & triple checked the connections & the TV will not recognize any signal on that input from my DVR. It maybe possible the DVR's YPbPr output is not working since I never needed to use it. Thanks in advance for anyone's 2 centz.
Old 09-09-2010, 09:22 PM
miniman82's Avatar
First Light: 1952-2011
You might need to tell the DVR to output to component, otherwise it might default to coax or something.
Evolution...
Old 09-09-2010, 09:52 PM
site123a site123a is offline
Some DVRs has the option to output progressive scan instead of interlace. Check if your DVR is set to interlace scan...
Old 09-09-2010, 11:12 PM
zenith2134's Avatar
surely this is a menu setting on the DVR. i've been there myself.
re: progressive scan vs interlaced;;;also true I once had a dvdp which upscaled to 720p and there were two menu settings which were capable of completely disabling the y/c svideo out and composite outs. This was if set to progressive scan.
Old 09-10-2010, 09:31 AM
Old 09-10-2010, 10:53 AM
Danny in Cleveland
Thanks for the replies. The progressive scan setting on my DVR will not stay on. It keeps defualting back to "off" after I set it to "on". No change with the TV component input recognizing a signal. I tried another DVD player with those component outputs and still no signal. I double checked the menu setting on both players. I think the new TV has a bum component input. What else?
