Old 07-20-2010, 08:33 PM
XDCAM's Avatar
XDCAM XDCAM is offline
Smile Help Please
I am trying to restore a LDK5 Camera (NO power for 21 years) made of different parts .Has anybody got a picture of the connections of the CCU/Power Supply as I have got no manual.Also can the power be applied with out a load (Camera) to dry out the Electronics and whats the routine of turning on this Chain please ?
Old 07-23-2010, 04:34 PM
BrianSummers's Avatar
BrianSummers BrianSummers is offline
TV Camera Museum Curator
ldk 5
HI XDCAM
sorry for delay in my reply, up to my neck in work this month, You can run the psu/base station up with out the camera, I assume it is the triax camera and not the LDK25 cable type. I have got the rear connections to the psu and will try to look them out before I go away to work again on sunday for another week.
The channel is fairly robust and on OBs we used to switch them on and wait for the camera to be connected. The CD driver card next to the PSU gave trouble in starting up and often had to be "warmed up literally" to get it to go.
Watch out for the tantalum capacitors, after a long period of unuse they can fail on switch on leading to a smoke signal.
good luck.
