Old 04-18-2010, 04:12 PM
TinCanAlley's Avatar
In need of a Zenith 9-121-01 video ouput board
Last year the video output board on my CCII went out (fried the socket). I managed to find a board on ebay that was still sealed in its box and had a "D" at the end of the part number. I'm assuming this was just a revision number.
About a month of used I started getting bright green splotches and flashes all over the screen. That would happen occasionally, so I ignored it. It then started to change from normal color to too much green and then too little green. It was as if the green driver was having problems remaining stable. Also, the G2 seems to do something similar as the screen gets a light raster at times when the video goes black during scene transitions (similar to when you put it in setup and rotate the G2 and see the raster). I tested the tube and it was good, so I'm assuming it's the video output board.
I have reflowed the solder, used deoxit on the pots, but it was of no help. I figure something goes out of spec when the board warms up, etc.
Since I'm at the end of what I can test for, it is time (again) to locate another video output board. So if anyone has one sitting around, let me know what you want for it.
Thanks in advance.
Old 04-18-2010, 05:09 PM
You need to follow the CRSP matrix for Zenith Modules - see this thread for some images of the CRSP manual - last image has the 9-121 info.
http://www.videokarma.org/showthread.php?t=247024
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 04-18-2010, 06:05 PM
Cheers,
Am I missing something here? I looked at the CRSP and it lists the part number and what it is. I have all that information. What I'm looking for is someone that might have a module they're willing to part with or where I might find one.
Thanks
Old 04-18-2010, 07:06 PM
Thanks
You stated your uncertainty about the replacement:
I was merely helping with that - nothing else. You didn't mention your chassis number, so I couldn't determine if I had a module to help you with. Without the chassis number, it would be futile. I do have some Zenith CC modules. I helped the OP in the thread I mentioned - he got two modules from me.
Jes' trying to help!
Cheers,
Old 04-18-2010, 09:51 PM
Okay, now I understand. The original module was a 9-121-01 (no letter at the end). I was told that the D on the replacement meant it was a revised module and would work fine with my TV (and it did for a month or so), so I purchased it. I looked identical to the one it was replacing.
Anyway, my TV is model: J1938W3 and was made in Sept of '77.
Hope this helps.
Thanks!
Old 09-03-2010, 09:57 AM
vistec vistec is offline
VK Member
Thumbs up we have the module
We have lots of the zenith origional modules
new and refurbished we also have several pulled but good modules
if intrested email us
[email protected]
some of the modules we have
r= factory remanufactured
p=pulled but good
9-121-01r
124-79-01 space command remote
9-86r subcarrier module
9-86-02 subcarrier module
9-90-02c Horiz afc & osc
9-103-04r audio amp
9-88-01r low level lum.
9-87r sync & agc
9-120-01r vert. osc & driver
175-1527p
9-91p
9-123-01x pulled
9-87p
9-92p
9-89p
9-57p
9-137p
150-214p
9-97p
9-90-01p
9-88-03
9-27p
9-48p150-190p
150-190-01p
9-103-01p
175-1611-c pulled
9-83p
124-32 remote used but good
124-138-20 remote used but good
124-79 remote used but good
