Old 04-07-2010, 11:22 PM
Kalamazoo-DJ's Avatar
Kalamazoo-DJ Kalamazoo-DJ is offline
1976 Magnavox
are these things real wood or composite material? looks are nice but pretty pricey any issues with chassis on them?
http://fortwayne.craigslist.org/fuo/1674055624.html
Old 04-07-2010, 11:41 PM
By this time, probably plastic and particleboard. The chassis is probably the T995 fold down modular chassis with 25V delta gun CRT. That chassis was probably the best Magnavox solid state chassis; but, $800? They must be smoking crack!
zenith2134's Avatar
Bring
A
Forklift
Old 04-07-2010, 11:46 PM
As far as chassis problems; I've seen loose and/or burned module connectors and I think this chassis used one of those 4 lead paper in oil safety caps in the HV circuit that Magnavox used in most of it's color sets during the '70's and early '80's. If it shorts, it will trip the CB. If it blows open and breaks it's interlock feature, you won't have HV. If it opens and the interlock fails to break, the HV will skyrocket and the CRT will be ruined. The last Magnavox set that I had (T809) with a shorted safety cap ended up getting a regular HV sprague orange drop cap in it's place.
Old 04-07-2010, 11:51 PM
ctc17 ctc17 is offline
I have a 1969 console and the body of the cabinet is particle board, the base is still hardwood. I would bet this is mostly particle board in 76.
Old 04-07-2010, 11:58 PM
I would consider it if it was much less but for that price it better be mostly solid type construction and perfect working not too far to fetch with a truck either.
Old 04-08-2010, 12:40 AM
And have some large amounts of gold hidden inside.
Old 04-08-2010, 12:44 AM
i can use the gold lol
Old 04-08-2010, 01:01 AM
Years ago, I had a Magnavox upright console TV/tuner/cassette/phonograph combination from around '84 and it used, IIRC, the 25C5 chassis. That was probably one of their last upright models. And, it was heavy as lead.
Old 04-08-2010, 03:53 PM
zenith2134's Avatar
My limited experience with Magnavox color sets begins and ends with the C3 (or C9?) chassis 19" sets. These were knob tuned NAP sets from about 1983-1984. I remember them having quite a nice picture. In-line gun totally SS chassis. One thing about the two I owned was that the crt's seemed to be pretty strong even though the rest of the set looked overused.
