Old 02-28-2010, 02:16 PM
When did you first observe CRT cataracts and Green halo?
To those old enough to remember 60's TV's when they were still being used in the 70's-80's, when did you first see Cataracts or Green halo? For that matter, how about the oily lens seal on a 21FBP22 that would break down and leave a vapor halo around the edge of the screen. Those oily lens seals would also make a mess inside the bottom of the cabinet.
Im just curious as when I find these sets with green halo etc., it would be interesting to know about how long they have been in this condition. I imagine many nice TV's were junked over the years simply because of cataract related conditions.
Old 02-28-2010, 02:30 PM
jstout66 jstout66 is offline
Hi Doug,
Good question. I worked in my Uncles shop from 1978-1982.
Surprisingly not a ton of roundies were in service. I don't ever remember cataracts on them tho, and NEVER saw them on rectangular tubes.
However, I DO remember the green halo on Zeniths. So... you figure if I saw a halo on a 67 Zenith in 1980, that set would have been 13 years old.
I've seen some of the "early generation" Chromacolor tubes now that have the halo, but not any made say past 1973. Hummmm......
Old 02-28-2010, 02:44 PM
Old 02-28-2010, 03:31 PM
I first saw it around 1990 on an early Motorola rectangular CRT table set. The set had been stored in a basement for years; but, it still worked other than the SEVERE cataracts. The cataracts was probably why it was taken out of service.
Old 02-28-2010, 03:38 PM
Tony V's Avatar
Tony V Tony V is offline
I saw my first cataract in 1982 on a RCA CTC16 combo that i had bought. It was severe enough that when i removed the tape, the safety glass fell off. So it had to have been that way for several years before i bought it.
Old 02-28-2010, 03:40 PM
truetone36's Avatar
electronics packrat
I first saw it on a CTC-16 in 1989.
Old 02-28-2010, 03:52 PM
David Roper's Avatar
console lover
Well, I got you guys beat by a mile. My folks' 1966 Packard Bell had a noticeable fuzziness at the edges by 1974. The repair man told them there was nothing that could be done about it short of picture tube replacement, which wasn't happening.
The PB was still hanging on into the early 80s (despite my rubber band and chewing gum repairs to it) by which time I had moved out and was using it as my primary set, ignoring the slowly growing cataract. It finally quit late in '83 and rested out on the porch. By the early 90s, the halo covered at least half the screen.
This set was, btw, a 23V type.
Old 02-28-2010, 03:59 PM
I remember seeing in the "lounge" area of our county airport, an early rectangular set that was beginning to look "Funky" by late '71-early '72. Don't remember what kind it was, & this place was frequented by SMOKERS...Guys who "Lit one offa one" over & over all day & all night. I DO remember the screen was a deep olive green, some of which undoubtedly was nicotine stain. I wonder if nicotine helped speed "Cadillacs" along...It would kinda make sense if it did...
Old 02-28-2010, 04:41 PM
I remember a Magnavox that Dad put a new CRT in because it had the green debond disesase (cataracts). This was in 1977 or 1978, before he moved to the big shop. It was probably a 23EG or 25AX tube, definitely not a roundie.
That said, I worked as a counter salesman for Cain Electronics in the early 80's. When we sold Channel Master CRTs, we had three tests for each CRT - check for label (to ensure the tube was indeed a dud candidate), check for air (used the sparky pencil - there's another thread on VK about it) and ask if the safety plate was debonded/had debond disease. We had to ask because the boss didn't want anyone of us sales folks removing CRT duds from cartons. If the dealer brought in his dud, he did the swap. Lots of CRTs went out the door sans the carton.
We sold a lot of 23VAL/23VAT "universal" 25" CRTs in the early 80's. We had Channel Master 2 year "Monarch", 3 year and Lifetime tubes. We also sold Empire Video rebuilt CRTs in the most common sizes for 2/3rds the cost of the Channel Master CRTs. Empire had problems with shorts after a year or so, but they were 1-yr warranty tubes, so very few got the warranty replacement.
Oh how I hated the Channel Master truck. Luckily, my brother was a suck-up and would come in early to help unload. I was happy to watch from the sidelines.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 02-28-2010, 09:41 PM
rca2000's Avatar
rca2000 rca2000 is offline
For me...it was in about 1978, and it was on a Motorola 23EGP22 set.
A grade-school friend had one, it was his parents " main set", I remember it had the dual--HO tubes and such. I SWEAR it also had some kind of "vertical channel readout", but with a mechanical tuner. IIRC, the set was becoming problematic by then, and there were 3 capacitors in a group in front of the big square power tranny, and one had been "knocked over" and was hanging by the leads.
The moved about the fall of the next year, I was about 12, and that moto set was NOT working right, I rememebr a TV guy there, and he changed a number of tubes, the 1V2 I am SURE of, and some others. The set was then working , to some degree... but the cataract was getting bad by then, and I remember asking about it, and the TV guy told me "it is the glue going bad that holds the glass on in the front of the tube". For some reason...they decided NOT to fix the set, and replaced it with a 19" Mits set.
I BEGGED for the set, but I did NOT get it. Jeff's mom did NOT like me very well, and no doubt convinced his step--dad who DID like me(and my mom too, to a degree..)that it was "too dangerous" for me to have the set. I have little doubt it ended up in a packer--truck. Not long after that--Jeff's mom's jealousy of his step-dad's attention to me and my single mom got to a peak...and she convinced his SF that I was a 'bad influence on Jeff",(in reality...it was the other way around..) and ended our friendship soon after.
In about 82 or 83 my uncle gave me a GE table model, probably from around '67. (KD? Something like that chassis) He mentioned that the picture tube was new so it should have lots of life left in it. This always puzzled me since it had a pronounced cataract, something which always annoyed me. (along with all the other bad traits of a 60s GE color set)
I started dragging home sets by the truckload in '90. Thinking back, most did not have cataracts, but I did end up with several roundies that had them.
Old 03-01-2010, 12:14 AM
freakaftr8's Avatar
Convergence freak!
I remember seeing the green halo on , believe it or not, a 13" motorola hybrid that used to be in a sandwich shop out in Orangevale in 1987. They had it down off the shelf once when I went in. They were repairing the rabbit ears on it.
Old 03-01-2010, 10:38 AM
marty59's Avatar
marty59 marty59 is offline
A friend of mine and his Mom had an "early" model CTC-17 (25AP22) and that set was about ten years old with a bad cateract. First time I ever noticed such a thing. That CRT was still going strong though and had a nice gray scale.
Funny thing about that one was that it was occuring from the lower right side, about a third of the tube. Must have been a bad bonding job from the start.
Old 03-01-2010, 11:19 AM
kx250rider's Avatar
REAL TVs have TUBES!
I saw the green ones on Zeniths as early as the late 70s, but later on roundies. I'd say 12-16 years was the age when the cataract would show up. The fix in the 80s was to have the local rebuilder remove the face glass and band the tube, which was the acceptable repair. Rebuilt tubes came that way also. On the oily 21FB, I saw that for the first time in 1977, when I was given my first color TV to play with... A Packard-Bell 21CT7. It showed up as a rainbow halo which would be visible on a white screen.
Charles
Old 03-01-2010, 03:28 PM
sampson159's Avatar
sampson159
in the mid 70s when began to get the halo and cataract crts.i do remember the first halo.it was a zenith 23v in a drexel cabinet.strong tube but the owner wanted it replaced.really good set and the halo wasnt really an issue.replaced with a genuine zenith.the first cataract was a ctc11.we didnt really understand it then,so the crt was replaced with channelmaster.nice looking tube when finished,very sharp.the old crt was put away and i think mr dixon did the "surgery".it was used in another set and actually it was a better crt.no safety glass reinstalled.late 70s saw a ton of these issues.looking back,it was good times!
