New Harvest: Packard Bell 98D7, 23001 MHW
Picked this up in Hollywood last night. It was used in the set of an older independent film and the set designer was letting it go.
The remote tuner control is a trip, theres allot about this set that looks ahead of its time. The tubes were removed for testing and they came in a bag with the set. So far the vertical output is cracked and the damper has an open filament. My dad worked for Teledyne (who sams lists as the manufacture of this set) and often speaks of the 'saw mill out back' where they made the cabinets. Also my crt tester came yesterday (Sencore CR31) I tested the crt in this set and the emissions show ok but I cant get it to come up on the GUN BALANCE measurement/setup at all. Im guessing this is cutoff..? Im still going to get this set going and see how it looks. I also check the crt in my Sears Silvertone that has a dim picture and it has hardly any emissions at all. Im trying to figure out if I should rejuvenate or use the restore function first. I did check a good crt and it checked ok. |
