Old 10-29-2009, 06:53 PM
devoid's Avatar
devoid devoid is offline
NA Volvos and Amplifiers
flyback, oem or generic
Are the generic flyback transformers reputable? I've got a RCA F36674ET chassis CTC197CA here with a bad one. RCA number 237506. I recall seeing a lot of flybacks going bad on the tuner on board and newer sets and have used a lot of generics is the past with good success. Wondering which one to go with. Both are cheap depending on the market.
What I don’t want is music that was written to be recorded.
Old 10-29-2009, 07:41 PM
000
Old 10-29-2009, 07:52 PM
devoid's Avatar
Good reasons to go OEM. I feel stupid for thinking only of reliability and not tolerances. Funky deflection drives me nuts. Been a few years now since I fixed TVs for my day job. I did check ebay and I think I'll go that for now on because there seems to be a surplus of oem units out there since everyone's going to panels.
Old 10-29-2009, 08:28 PM
Go with an original RCA or HR Diemen, if possible. I have used many generic transformers with different results. Sometimes, the original is either NLA or very expensive, in which case I'll go with a generic. I remember the cheap "no name" generic that I stuck in a CTC179 that blew up in my face after about two hours of operation. I installed the transformer, played the set for about two hours, turned it off for the night, turned it on the next morning, and the transformer blew apart as soon as I hit the power button. Another problem I've had with generics is getting the terminals to line up correctly with the PC board.
Old 10-29-2009, 09:54 PM
000
Old 10-29-2009, 10:04 PM
devoid's Avatar
Got my cake and ate it too. I procured this.
Old 10-30-2009, 01:25 PM
Zenith26kc20's Avatar
Smart to go OEM. I have had too many generics not work properly. Hate to say it, but I'll junk the set now before I go generic if the original is not available..
This is especially true for Sharp's and Zenith's.
Old 10-30-2009, 01:38 PM
devoid's Avatar
Ahh! The Sharp. Never forget the generic I put in one of those. Had a split in the anode lead right out of it. Guess how I discovered that?
Old 08-06-2010, 02:46 PM
Wizard256 Wizard256 is offline
OEM or Diemen.
Generic flybacks were horrible. Tend to be low HV or too soft due to too high resistance in HV winding.
Cheers, Wizard
