Old 10-07-2009, 06:35 PM
freakaftr8's Avatar
Convergence freak!
New DVD format seems to have an advantage
New DVD rentals watched in fullscreen seem to be stretched vertically it seems lately. They really look exceptionally perfect when I added a ressistor with a switch on the rear of my zenith 23XC36 to compress the vertical. This is really a cool thing considering all these movies seem to just be stretched from a widescreen format now and not written in 2 seperate formats like they used to be. I'm going to snap off a pic for you guys to see.
Old 10-07-2009, 06:44 PM
I hate the new DVDs, the stretch drives me nuts! I guess I'll mod one of the 70's Zenith sets laying around here like you did. I'm not touching anything older with mods like that.
Old 10-07-2009, 07:03 PM
freakaftr8's Avatar
Convergence freak!
Eah I hate the fact that I did the mod too but it beats watching them like they are now. At least nothing I have done is perminent. But the up side is a very digital like picture with the line compression. The down side of course is convergence. The bottom R/G horiz convergence throws off a bit. But a slight tweak and it's good to go. I may consider a switch and resistor for that too. Considering all I do with this set is watch DVDs I find Im never switching it back.
Old 10-07-2009, 07:17 PM
zenith2134's Avatar
I like the idea of adding a vertical "compensation switch"--- excellent thinking.
Old 10-07-2009, 07:41 PM
Shawn-
I don't think there is a "new DVD format". Rather, your player may have got set to 16:9 mode by mistake. (If your player has some kind of "full screen" setting, that could be another cause entirely.) The three typical settings on DVD players are: "4:3 letterbox", "4:3 pan and scan" and "16:9". 4:3 letterbox manually adds black bars on the top and bottom of widescreen movies (unless the disc itself has the black bars encoded, mostly older DVDs). 4:3 pan and scan chooses the pan-and-scan version of a movie if both versions are on one side of a disc; it does NOT manually make a wide-screen movie fill the screen (again, unless it is one of the few odd players specially made to do that). In either of these modes, a true 4:3 DVD (such as one with a TV show, or one of the awful modified "full-screen" movie versions) will fill the 4:3 standard TV screen with video. 16:9 mode is usually for component-mode inputs on HD-capable wide screen TVs, but it also works on the composite output (and there have been a number of wide-screen (16:9) non-HD TVs made, especially in Europe). If you choose 16: 9 and feed an RF modulator, you will get exactly what you describe, a movie with tall, thin characters (or stretched-out ones, it is the same effect).
In the pre-HD but early-DVD days, there were mods described to do exactly what you have done with your Zenith, and for precisely the reason you describe: Using all of the scan lines of the TV on the 16:9 area to get a higher resolution than the 4:3 letterbox setting allowed. Often, the mod included a switch controlling a relay (or relays) that had enough poles/switch contacts to change all the needed circuits, such as three vertical circuits in a three-CRT projection TV. I almost did this with my 61" Sony set in the year 2000.
Considering all I do with this set is watch DVDs I find I'm never switching it back.
Roundie color TVs and older rectangular sets are ideal for watching letterboxed content, as you have found out.
Old 10-07-2009, 08:02 PM
I subscribe to BlockBuster and they send DVDs like this, there has been nothing I could do to change it. Menus are useless, and no option of 4:3 format. Letterboxing is ok but this is the pits. There is something different with the format now. I noticed it a few months ago when we subscribed. I have a set that I adjusted to look right but now I might do the reversible mod to one, still nothing pre 1965
Old 10-07-2009, 08:36 PM
000
Old 10-07-2009, 08:41 PM
I set the DVD player menu to 4:3 and it looks the same There wasn't an option for 4:3 in the disc menu. Older discs had an option of wide-screen and regular. I don't mind letterboxing as it is good for roundies. But these discs are not doing what I want them to, I don't understand why it's not letterboxing them. Maybe my "Sony" DVD player is what sucks. Hmmmm...
Old 10-07-2009, 09:14 PM
cbenham's Avatar
cbenham cbenham is offline
Originally Posted by zenithfan1 View Post
I set the DVD player menu to 4:3 and it looks the same Maybe my "Sony" DVD player is what sucks. Hmmmm...
This is also a problem with the new Blu-Ray disks of classic academy aperture [1.37:1] films like Wizard of Oz, Pinnochio and Snow White. The BDs have been authored to prevent the screen size and shape controls in the BD player from operating //at all//. If you watch one of these BD films on a 16:9 HD set you get
an almost correctly shaped image with black pillar bars on the left and right.
However if you watch it on any 4:3 set, the image is either square [1:1 aspect ratio or 4:3 but reduced in size with black bars on all four sides. So far I've not found any BD player that will override the authoring of the disks and fill a 4:3 screen properly. Three pics showing the problem... Cliff
File Type: jpg OZ SQUEEZED 1 to 1 aspect ratio of NTSC Blu-ray output.JPG (35.8 KB, 32 views)
Old 10-07-2009, 11:04 PM
000
Old 10-09-2009, 12:16 AM
The Blu-ray format (and HD DVD, while it existed) has no provision for 4:3 displays at all that I am aware of, at least in any HD modes. As you said, the aspect ratio of The Wizard Of Oz is correct when viewed on a 16:9 display, and that is exactly as intended. Using a Blu-ray player on a 4:3 display is a compromise at best (some players will not even give you a picture from the non-HD outputs when a Blu-ray disc is played), and a headache (as you found out) at worst. It is ultimately best to stick with regular DVD players and discs if you want to use a non-HD, 4:3 (or round) display.
Old 10-09-2009, 12:24 AM
You need to have the disc stopped to get into the player's setup meny, but I think you already got there OK. Does your player have only two options (4:3 and 16:9), and not three (as I described in my post above)? If the player does not have the "4:3 letterbox" option next to the 16:9 option, it is probably there but in a different menu (in the player setup, still, with the disc stopped). If this setting is wrong, it will likely give you the problem you and Shawn have described.
I have not used a non-HD disc player for several years, so that is why I suspect they might have moved the letterbox-versus-full-screen option into a separate menu, perhaps.
