Old 06-25-2009, 10:12 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Zenith Porthole on...
Another Zenith Porthole on the bay.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=230343362637
No affiliation. I'm clueless as to what these are worth.
Old 06-25-2009, 10:16 PM
Not that much.. not in that condition.
Old 06-26-2009, 06:54 PM
Did it get burned on the side or what?? Another one thinks they have a gold mine. Maybe a 100 but not 5. If it has a good CRT it would be worth fixing up but geeze....
Old 06-26-2009, 10:35 PM
WISCOJIM WISCOJIM is offline
This one's more realistic: http://cgi.ebay.com/_W0QQitemZ280362556914
Old 06-27-2009, 12:37 AM
John Marinello's Avatar
<-- "Byron"
Originally Posted by WISCOJIM View Post
Zenith had 2 16" mahogany combo sets that year, and that one is the crappier one. The doors are fake wood grain, and the radio has 8-tubes, instead of the better 10-tube that has push buttons on either side. The 16GP4 is cracked also.
Old 06-27-2009, 01:40 AM
500 bucks , the seller is nuts !
Old 06-27-2009, 12:00 PM
I've never been able to get excited about the porthole combos. The postwar Zenith radio design is fugly. And, as with all roundies that lack a mask, you either look at a rectangular picture in the middle of the screen, or overscan the vert/horiz so that you fill the CRT and miss the corners of the picture.
On the other hand, if you can't live without a combo, I guess there are uglier ones
Phil
Old 06-27-2009, 12:54 PM
David Roper's Avatar
console lover
The sets are equipped with a switch which allows you a choice of normal scan, which shows in the pumpkin shape of any roundie but with unmasked black wedges above and below; and full screen, which stretches only the vertical, giving tall skinny people and egg-shaped circles.
Old 06-27-2009, 02:11 PM
Still would like to have a tabletop 10 or 12" "Claridge" model....They are just SO "1950" looking...
Old 06-29-2009, 10:57 PM
ha1156w's Avatar
ha1156w ha1156w is offline
Wouldn't that be the awful 16BP4 metal-cone tube in that thing? The one that is unobtanium and usually gone to air if you can find them??
Old 06-30-2009, 10:25 AM
<-- "Byron"
Perpetuated B.S.
If you store them in a damp location long enough, they will rust, and that may cause the faceplate to crack. Note the crack in this one at the 1 o'clock position, and note how rusty the back & chassis are:
http://cgi.ebay.com/_W0QQcmdZViewIte...lenotsupported
Also notice in the photo, one up from bottom, there is a screen above the speaker that is completely clogged up with nesting material! Whoever pulls the TV chassis is gonna be in for a big surprise!
I have a pile of 50+ year-old metal tubes that are still under vacuum, and I have NO doubt that they will still be under vacuum 50 years from now.
The mahogany Zenith uses the 16GP4, and the blond one uses the 19AP4.
Old 07-01-2009, 05:35 AM
I've always wanted a porthole , but never got on local .
I can imagine the $$$ one would cost to ship ,not to mention a combo ...
Old 07-01-2009, 02:26 PM
ha1156w's Avatar
Well what was the tube type in the Dumont sets that everyone talks about being impossible to find and prone to failure? RA-109 I think?
Old 07-01-2009, 02:50 PM
<-- "Byron"
Update your location to something other than "At large again", and I, for one, would be happy to keep an eye open for you.
Old 07-01-2009, 03:27 PM
<-- "Byron"
Dumont made some of the best quality sets at the time. They also developed & manufactured CRTs, and most of these were unique to their sets: 12JP4, 15DP4, 20BP4, 30BP4. Dumont & others used the metal 19AP4, which is probably the one you are thinking of. Not mant rebuilders want to fool with metal CRTs either, because they require a longer oven cycle when they are rebuilt, otherwise they may implode. This is why some tubes are so scarce.
If you are considering restoring a vintage television, it's best to do a little homework first, and bring a CRT tester with before you buy the set.
The last I checked, B&W CRTs were a minimal of $250 (+ shipping) to have rebuilt, metal CRTs were $450. Not many sets justify that kind of expense.
