Old 06-25-2009, 06:18 AM
jshorva65's Avatar
Whatintheworldisa Wobbulator???!!!
Well, I saw the term "Wobbulator" used in the Alignment Instructions copied by Rider's from original Dumont service literature for a Dumont set while I was restoring it. This particular split-chassis version of the RA-104 wasn't featured in Sams, although there's a Sams for a similar model having its HV cage on the main chassis. I obtained the Rider's manual for that one, and learned that a Wobbulator was the Tel-Instrument Company (TIC) trade name for a specific model of Sweep/Marker apparatus. Looking around a bit, I located two Type 1200A Wobbulator units for sale in upstate NY. ROAD TRIP!!! I ended up scoring both of them along with three "roundie" Zenith color sets, two color CRT's (a NIB/NOS Philco 21FJP22A, and a used 21GVP22A) as a package deal.
One of the two Wobbulator units was in Good condition (minor scratches and dents, but complete), the other in Fair condition (more scratches and dents, missing four of the twelve plastic pushbutton caps). Inside, the units are of modular construction. There are actually eight independent Sweep/Marker Generators inside, one each for the VHF High channels (7-13) and another single unit for the five VHF Low channels (2-6) which shares its chassis with the channel-switching logic, two stepper relays, and an array of calibration controls. There is also a regulated power supply module and a cooling blower inside the 19"x19"x19" metal chassis. The front panel features the On/Off switch, AC Input, Fuse holder, Marker On/Off switches, two fixed and one variable Attenuator, plus RF Out jack, binding posts for scope Horiz output, twelve pushbuttons for the Channel presets, and the Pilot Lamp. I have yet to find a Manual for the unit, but will only need one for Calibration. The circuitry inside was so straightforward and intuitive that I had the recapping done within 2 days of returning from the road trip. When I hooked it up to a scope and demodulator probe, the unit powered up and operated about as well as I expected. The unit produced the expected sounds of: the soft whirr of the blower motor; the hum of the EMR unit(s) (which is louder for the VHF Low channels than for the VHF High due to the approx. 10 MHz sweep width representing a greater deviation percentage at the VHF Low frequencies than at VHF High); and the "thump" of the stepper relays' cycling as I stepped the unit through the presets. The unit powers up, blower runs, switching logic operates correctly, Sweep is produced on all channels, and Markers are produced on most channels. Another swabbing of the stepper relays' contacts with rubbing alcohol and Calibration after I obtain the Manual should allow me to perform tuner alignments with remarkable efficiency for those tuners which needed "major surgery" to restore and to do performance testing of tuners which seem to be working well after simple cleaning. This unit and its sibling unit were once used in the Stromberg-Carlson Co. factory, presumably for alignment of the Mallory Inductuners used in the Dumont-clone sets (like Jamie's TV-12) on the production line. Metal tags attached at the upper left corner of each unit's front panel have "S.C. Co." stamped on them.
Once I get the lighting correct for a video, I plan to post a clip on YouTube of the unit in operation, and title the clip "Whatintheworldisa Wobbulator???" which was inspired by a t-shirt sold in my hometown back in the 70s which read something like "Whereintheworldis Warren, Ohio???"
Old 06-25-2009, 06:26 AM
Warren, Ohio, was also the original home of Packard, one of the finest motorcars that was ever made...
Old 06-25-2009, 06:38 AM
merrylander's Avatar
merrylander merrylander is offline
Ask the man who owns one.
Some people are like Slinkies, not really good for anything. They do bring a smile to your face when you push them down the stairs.
Old 06-25-2009, 06:57 AM
Yep...Too bad you can't really do that much anymore. The Packard club people, however, are fiercely proud of their cars. But the last "real" new Packard you could buy was a '56...The 1957-58 "Packardbakers" are best forgotten. Getting back on topic-What a strange concept for a ardent thread hijacker like me- "Wobbulator" seems to be more of a British term than one used on this side of the pond. I've seen it used in some of the seditionist Boatanchor propaganda I have perused, typically in conjunction w/the Racal RA-17, which was the Brit answer to my beloved Collins R-390A...
Old 06-25-2009, 08:34 AM
electronjohn's Avatar
I like....big sparks!!
It's just a Wheelabrator that wobbles, that's all.
Old 06-25-2009, 09:26 AM
It is a European name for a sort of sweep generator.
Old 06-25-2009, 12:39 PM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
next someone'll be asking about snivets...
all the best,
mrh
Old 06-25-2009, 01:01 PM
Arkay's Avatar
Arkay Arkay is offline
I thought a Wobbulator was something Charlie used in the Chocolate Factory... or was it one of those pieces of gear behind the Wizard of Oz's curtain?
OOOooooh, yes, truly outstanding automobiles. My "dream car" is a long-wheel base Packard V12, circa 1937. Supremely elegant design, very luxurious, whisper quiet, and able to handily overtake freeway traffic all day long with a monstrously powerful engine (if you dare to push any car that old, that hard). Enough weight/mass to crush the daylights out of almost anything else in a collision, too... although the thought of crashing one of those beauties makes me cringe!
I wish... one day!
Cowardly wild cats, right? [A contraction of "snivelling civets", of course.]
Or are they snipped-off rivets?
Be yourself. Everyone else is taken.
Old 06-25-2009, 01:11 PM
I have an unrestored Triumph Oscillograph-Wobbulator, built for the Navy under a wartime contract.
http://www.antiqueradio.org/trium01.htm
Cute little bugger. I've had it more than 10 years -- guess I should either restore it or send it packing. Somewhere in my paper piles is the service manual.
Old 06-25-2009, 08:00 PM
Whirled One's Avatar
Weeblators wobbulators but they don't fall down.
Old 06-25-2009, 08:08 PM
The first time I ran into the term was in a 1939 GE H-87 radio manual. It was used to adjust the IF stages to give a even/broad curve for hifi responce. Akin to a sweep generator.
Terry
Old 06-25-2009, 08:59 PM
zenith2134's Avatar
News to me! Cool...
Old 06-25-2009, 11:56 PM
cbenham's Avatar
cbenham cbenham is offline
[QUOTE=7"estatdef;2837099]The first time I ran into the term was in a 1939 GE H-87 radio manual.
In the 1950s one TV manufacturer included a 'wobbulator' circuit in a few sets to make the scanning lines disappear. It was a ~14 megacycle power oscillator driving a third yoke coil that moved the beam vertically by a very small amount, but just enough that it covered the blank areas between the lines on the screen without making the picture look out of focus.
I don't remember which company did this but maybe someone reading this does???
Cliff
Old 06-26-2009, 12:35 AM
David Roper's Avatar
console lover
Yes Cliff, I remember reading about that application too, but only in connection with British TV set manufacturer(s?). I could see a greater desire for it there since the lines themselves are a good deal more pronounced on the 405 line sets once you get up to 21" screens.
Old 06-26-2009, 12:40 AM
Wobulation (with only one B) is also a recent term used with DLP TV sets. It refers to making a lower-resolution DMD panel create a higher resolution by reflecting light in multiple angles, more or less.
