Old 02-02-2009, 02:35 PM
mr_fixer's Avatar
mr_fixer mr_fixer is offline
Small Color Portable Sears at GW Today
Here is something kinda cute I found at GW today. The lines in the close up pic are caused by being too close to my computer. It is a model 934 40053090 made in 1990. It has audio and video inputs so it will have a life after the DTV conversion, Logan
Old 02-02-2009, 03:10 PM
Neat! I've always liked the little 5" portables. Looking for a Sony KV 5000 or newer now.
Old 02-02-2009, 03:14 PM
Kewl !
Old 02-03-2009, 02:01 AM
ha1156w's Avatar
ha1156w ha1156w is offline
Looks very much like my Crown Japan (labeled with "Megatron" stickers over the Crown badges). Same style handle, antenna, and control layout too. Not sure when it was made, but it indeed has AV inputs as well. The color fidelity is suprisingly good. My only pick is that the voltage regulation seems a bit lax allowing the picture to shrink/grow depending on the overall brightness of the image.
Old 02-03-2009, 03:29 AM
I have a Sharp that looks very similar, it has the video input also.
Old 02-03-2009, 01:23 PM
jhalphen's Avatar
jhalphen jhalphen is offline
Hello Gentlemen,
Another small "color cutie" is this RCA PVM-35. It has a 3.5" screen, VHF/UHF reception and A/V input via 3.5mm mini-jack, so you can use it with your ATSC converter box.
Another nice feature is that the power supply clips on the back like on the Sony KV-4000, so it's a clean design with no wall-wart or PSU lying on the floor.
It looks a lot like the JVC TM-P3, but the RCA has OTA reception whereas the JVC is only a video monitor.
Very nice picture, uses an in-line color CRT with fine pitch rectangular phosphors.
Best Regards
jhalphen
Paris/France
Old 02-04-2009, 01:38 AM
mr_fixer's Avatar
Aw, that is very Cute little set!
