Old 01-26-2009, 06:57 PM
jaspars7 jaspars7 is offline
RCA Scenium ***DEAD***
Now I've got a problem with my RCA Scenuim. It just went out and when I push the power button, I hear the fan kick on, power button lights up and then it shuts off. I turn on power again and it does the same thing. I took the back of the TV off and found the exact same restrictor burnt to a crisp. Assuming that I have the same problem, I followed the advice given and replaced the HV Splitter which was smooth sailing and then I replaced the restrictor by connecting it to the two on the right side of the board as instructed. After installing the new parts, I crossed my fingers and hit the power button and, no luck. Still doing the same thing it was at the start. I'm gonna take a few pics and post them up so you guys can see what I've done. In the meantime, any ideas? In the back of the TV, on the right, at the bottom, inside the bottom box, I can see a red light that comes inside when I plug it in and the fan starts up, but after a few seconds, it shuts off and then tries to start back up about 3 times before it just shuts off.
