Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Movies, shows, & programs
Old 12-12-2008, 05:08 PM
pioneer54's Avatar
pioneer54 pioneer54 is offline
hd tv
i live near the U S boarder and receive both detroit and cleveland broadcasts. i'm on antenna so come feb i'll need a converter box. trouble is i can't get one in canada. we don't change till 2012. what's a box worth?? or do most recommend getting a new tv. shame to dump the cathode.
to fish
or not to fish?
what a stupid question.
Old 12-12-2008, 07:28 PM
tboat4's Avatar
tboat4 tboat4 is offline
I've heard the boxes start at about $49US.
I've learned that people will forget what you said, people will forget what you did, but people will never
forget how you made them feel. - Maya Angelou
Old 12-12-2008, 07:37 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
I got one NIB on eBay for $20. Used the two coupons already and needed a 3rd and this one will operate on 12VDC too. Something to consider if you have a battery operated analog TV for emergency use.
Old 12-12-2008, 08:53 PM
whoaru99's Avatar
whoaru99 whoaru99 is offline
Sorry to be nit-picky, because I know what you mean, but don't confuse digital and the transition thereof with high definition TV.
Most digital transmissions will not be high def and the inexpensive converter boxes don't possess high definition capability.
Unless you are wanting a new TV there is no reason to buy one just because of the transition. As has been posted, converter boxes can be had for MUCH less than the cost of a new TV.
push back against dubious claims that defy logic;
be on the lookout for misrepresentations;
question the lack of science when belief is the substitution;
be very skeptical when the denial of the laws of physics comes into play.
--jpaik
Old 12-12-2008, 11:24 PM
pioneernut's Avatar
pioneernut pioneernut is offline
I need help
Hey those converter DTV converter boxes aren't that bad on standard TVs. I got two, a Magnovox from MalWart, and an Insignia from Best Buy. Both are have a clear picture, but I like the remote and usability of the Insignia. I think it was $59, vs te 39 for the Magnovox.
I found the picture resolution to be a huge improvement over the feed that Dish Network sends down of the local channels, plus the fact that they can send muliple channels on one stations just about doubles the number of programs.
Pioneer Elite M-91 C-91 M-72 F-91 PD-65 CT-91a DV-09 SP-99D
Pioneer A-717 F-717 PD-7100 CT-S800 CT-S600 DSS-7 RT-701 PL-610 CT-F615 SX-1500TD SA-900 TX-900
Sony TC-640 Technics SL-D2 Teac A-4300SX
KLH Model 17 Polk S-6 AR-4x DBX-224
Homepage www.elitebypioneer.com
Old 12-13-2008, 03:41 AM
harleyrider's Avatar
harleyrider harleyrider is offline
Im on Dish network , just the standard stuff i havent ordered the HD yet . My tv is a Philips 50" Plasma 2 years old, i notice that the pic isnt all that great . Not crisp and clear as i thought it would be . Will these boxes help out , or do i need the Dish network HD upgrade to have that true Hd quality picture ?????.
Pioneer Spec1 Spec2 TX9500II SG9800 EQ Rt707 RR , Realistic Lab 400 Denon DCD 810 Philips 50"plasma Klipsch CF3s 2 sets,
Old 12-13-2008, 09:47 AM
whoaru99's Avatar
The converter box may or may not give you a better picture than you currently have, but almost certainly wayyy less channels.
One thing is absolute and that is that these $40, give or take, converter boxes are not high definition receivers/tuners.
There is at least a 50/50 chance your Phililps TV has a digital tuner built in that makes the converter box unnecessary to receive digital broadcasts OTA (over the air). Check the specs to see if it has an ATSC tuner.
ATSC tuner = digital tuner for receiving OTA digital broadcasts
QAM = digital tuner for receiving digital CATV channels
NTSC = analog tuner for receiving analog CATV or analog OTA broadcasts
The bottom line is if you are going to stay with Dish Network, yes, you do need the HD upgrade to get HD picture.
The other alternative is to check the TV spec for the ATSC tuner I mentioned and if it has one, connect an antenna to see what you can pull in for free OTA. There's a decent chance you'll get at least one or two channels in true high def. Depending on what's transmitting around you, you may need a VHF antenna or UHF antenna. Antennaweb.org has that information.
--jpaik
