Old 11-19-2008, 10:03 PM
toxcrusadr's Avatar
Anyone built a crystal radio kit?
I'm looking for a recommendation on a crystal radio kit that laypersons could build. Our local community radio station asked me if I'd be interested in leading a sort of workshop, to get people interested in radio and have a little fun building a crystal radio. I said that might be fun and I would look around for a good quality kit. Any suggestions?
Old 11-19-2008, 10:43 PM
pioneernut's Avatar
pioneernut pioneernut is offline
I need help
not exactly a crystal radio kit, but I had one of these when I was kid. Looks just like the one from Radio Shack back in 79'
http://www.ramseyelectronics.com/cgi...action&key=AM2
Here's another possibility, see the first item
http://www.oselectronics.com/ose_p144.htm
I'm pretty sure you can make one with a coil of wire, germanium diode as the crystal and one of those little earphones. I think those are crystal headphones too. Your typical set of stereo head phones have too low of impedance to work.
Pioneer Elite M-91 C-91 M-72 F-91 PD-65 CT-91a DV-09 SP-99D
Pioneer A-717 F-717 PD-7100 CT-S800 CT-S600 DSS-7 RT-701 PL-610 CT-F615 SX-1500TD SA-900 TX-900
Sony TC-640 Technics SL-D2 Teac A-4300SX
KLH Model 17 Polk S-6 AR-4x DBX-224
Homepage www.elitebypioneer.com
Old 11-19-2008, 11:40 PM
I had one of those from radio shack too. Looks the same except for the artwork.
Old 11-20-2008, 01:54 AM
The Xtal Set Society sells a range of crystal kits:
http://www.midnightscience.com/kits.html
You can also buy a basic kit from Antique Electronic Supply:
http://www.tubesandmore.com/
If this will be a group project, you might consider building a kit yourself beforehand, and trying it out in the location where your group will be working. It might be disappointing if everyone completes their project and you hear a chorus of "Can you hear anything?" "I can't hear anything!"
Old 11-20-2008, 04:19 AM
Fisherdude's Avatar
Fisherdude Fisherdude is offline
The Golden Age of Hi-Fi
I'll echo the test it first suggestion.
And, keep in mind that a crystal set needs a pretty good antenna and a good earth ground to function properly.
I may be growing older, but I refuse to grow up.
Old 11-20-2008, 07:17 AM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
You don't really need a kit to build a crystal radio :-)
All you need is a BC tuning air-variable cap, maybe a trimmer, a germanium diode, a crystal headset or earphone, and some wire (actually, a lot of wire, unless you live very close to a transmitter)!
www.tubesandmore.com has everything you need.
There are also plans and designs for more and less sophisticated crystal radios (even FM!) on the web and in a variety of books (see the link above).
Maybe building a superregenerative receiver would be a little more interesting and give you a little more reception capability... :-)
EDIT: oops, except for the last sentence, you already got all of the above from earlier posts! Sorry :-P
all the best,
mrh
Old 11-20-2008, 07:20 AM
merrylander's Avatar
merrylander merrylander is offline
Sure, about 64 years ago.
Some people are like Slinkies, not really good for anything. They do bring a smile to your face when you push them down the stairs.
Old 11-20-2008, 08:32 AM
bmack bmack is offline
Here is a good resource for crystal radios. He has a nice collection of old crystal sets, parts, plans for building, etc.
http://oldheadphones.com/crystal/index.html
Old 11-20-2008, 03:05 PM
toxcrusadr's Avatar
Thanks for the links. This will be un-scientific types each building their own, many of them artsy types. If I was doing this myself I would use what I have - actually made a razor blade foxhole radio from junk once - but it's probably not a good idea to send THESE people off with a shopping list for air-variables and miles of wire to wind their own coils. A simple kit everyone can buy may be the way to go. I'll look around though. Maybe we buy the coils, get the headphones and diodes in bulk...
Old 11-20-2008, 03:34 PM
Brian Brian is offline
I've got one I built not long ago ad anotherI bought not long ago but have not built. I'll dig them out and get the information as to manufacture. Each was something like $10. Big decision for a kit is whether the maker should wind the coil or it should be prewound as it is the most difficult part of the project.
Old 11-20-2008, 04:38 PM
NYListens's Avatar
NYListens NYListens is offline
CBGB & OMFUG
I built the oatbox radio a few years ago. It was pretty easy and didn't take much time other than ordering the parts.
Vintage System: Fisher 500B, Technics SL Q202 (Ortofon VMS 30), Tandberg 3000X, Denon DCM 290 through a pair of Apogee Centaur Minors
Workshop System: Fisher 500-S, Pioneer PD M-400 through a pair of Acoustic Research AR 8BXIs
New project: overhaul of a Scott 340B
Old 11-20-2008, 07:33 PM
Or wht about a foxhole radio? Only parts you'd need to acquire would be wire, an old lead pencil and some razor blades and a crystal or magnetic earphone. A little scrap of wood, an old tissue roll and you areset to go.
Old 11-21-2008, 08:05 PM
kbmuri's Avatar
kbmuri kbmuri is offline
http://bizarrelabs.com/foxhole.htm
http://en.wikipedia.org/wiki/Foxhole_radio
Good reading.
Do not attempt to adjust your set.
Old 11-21-2008, 08:19 PM
The Foxhole radio is actully a product frm WWI. If anyone has a set of The Book Of Knowledge from the '30s, the history and construction details are in an article. I thik the set I had as kid was 1935. In the article it was called a foxhole radio and also the trench radio. I suspect the thought that it originated during WWII is from the name foxhole that is associated with the foot soldiers digging in.
Old 11-22-2008, 12:58 PM
Philcofan42's Avatar
Philcofan42 Philcofan42 is offline
I built one of these recently. I wound my own coil, found a blue razor blade and along with the safety pin/pencil lead I just used metal push pins to hold everything to the board and make the connections. I used a large paper clip as a fine tuner. It works very well and was a fun project. Most people have never heard of these things and everyone was amazed that you can get stations on something so "Mcguyvered". I agree that the ground and antenna wires are crucial to making these or any crystal radios work. I bought one of those Smithsonian kits at the toy store. It's a breeze and works great once you get the wires hooked up. I've built a couple crystals from scratch and they are pretty easy to do. The best one I've found is not a kit, it's the "Crystal Rocket Radio" from Restoration Hardware. It's a replica of a radio from the 50's. The best thing about it is that it only has one wire that acts as both antenna and ground so you can use it just about anywhere you can find some grounded metal to clip it to. The major disadvantage with most simple crystal sets is that you are only going to get one or two stations, but they are more about fun than function.
