Old 11-01-2008, 07:34 PM
DR_Simpkins DR_Simpkins is offline
Sanyo tuner problem?
I have a Sanyo 27 in. that won't work on TV (acts like it isn't getting any signal at all) but will play DVD's all day long. A cable TV guy said the tuner was bad. Is it difficult to resolder or replace tuners?
How many leads would have to be resoldered or desoldered to remove one? Do I have to take the metal cover off the tuner or what?
Thanks for any info I can get.
Old 11-01-2008, 07:46 PM
Before you blame the tuner, there is a resistor (39K ohm, IIRC) that will open and kill the 33 volt supply to the tuner. If the voltage to the tuner is OK; it probably is the tuner. Try www.matelectronics.com. They have many tuners at reasonable prices and may have what you need.
Old 11-08-2008, 05:14 PM
Thanks radiotvnut, I'll check and see if its that resistor. I'm using it now with a cable box as the tuner and using audio and video outs from it but I'd like to be able to do away with the cable box.
