Old 09-19-2008, 09:07 PM
Mystery
About a week ago, I was installing a new DVD player in my video system (the one I had finally bit the dust after only three years ). No problems installing the new player, but my TV (RCA CTC185A7, 19") fell off its stand while I was trying to get a better look at the back, so I could make the cords look neat. The TV, miraculously, worked after I picked it up off the floor in my apartment and put it back on the stand (it had landed face-down, so I was concerned as anything that the CRT might implode). However, I noticed, after hooking everything back up and turning the set on, a couple of large color splotches, one pink in color in the upper left corner of the screen, the other green and about a third of the way down the right edge of the screen. The rest of the color picture, again to my pleasant surprise (and relief that the set wasn't damaged), was normal.
I tolerated this for a day or two, then, getting tired of seeing these splotches ruining my set's otherwise excellent picture, I decided to try something, in hopes of getting rid of the color distortion. I remembered that I had a spare permanent-magnet (PM) loudspeaker stored in a box in my bedroom closet, which gave me an idea. Could the magnet be used to eliminate the color splotches on the picture?
I had nothing to lose, so I took the speaker out of its shipping box and brought it into my living room. I turned the TV on, and, when it warmed up and showed a picture from one of the local stations, I put the magnet against the safety glass in front of the tube and moved it around a bit. I could see the colors distorting as I moved the magnet around the glass, but when I moved the speaker well away from the set the picture was absolutely normal.
Now to the mystery. I said that my TV's picture was normal after moving the speaker magnet away from the CRT. True, but I also noticed, to my surprise, that the pink and green color splotches in the corner and the right side of the tube, respectively, were gone as well; they did not return and have not returned since. Here's the mystery question. Why would the use of a magnet eliminate splotches such as those I just described? I would have thought a magnet anywhere near the CRT, with the television on, would make any pre-existing color distortion even worse than it was originally. Also, I remember reading somewhere recently (perhaps it was somewhere in this very forum) that modern CRTs can be permanently damaged if they (or the TV set in which they are installed) receive sharp blows, causing the color distortion I just mentioned--or worse. If this is true in most cases, why was I able to eliminate the splotches on my set's CRT, using a magnet? Again, I would have thought the magnet would remagnetize the shadow mask, making any color distortion worse than it may have been in the first place.
Old 09-19-2008, 09:19 PM
MRX37 MRX37 is offline
You may have slightly distorted the shadow mask, and your magnet fiddling compensated for it?
Old 09-19-2008, 09:26 PM
Blast's Avatar
Blast Blast is offline
blast, blast...
It took a stronger degauss than the internal degaussing coil could supply. During this "day or two" was the set turned on and off with plenty of time in between on's and off's? If so, the internal degaussing coil SHOULD have taken care of the problem unless you severely bent the shadow mask (or the degaussing coil doesn't work). I have installed magnets on the rear of CRT's to compensate for bent shadow masks. However, if the mask is too far gone you won't be able to bring it back.
Old 09-20-2008, 11:17 AM
I'm not sure if the degaussing coil in my set works or not (I can hear a relay clicking when I turn the set on, but that's about it). I did turn the set on/off several times after putting it back on the stand, with no results (that I could see, anyhow) from the degausser. I don't think the shadow mask is permanently bent, as the picture is good now (no color splotches anywhere). Why the degausser didn't eliminate the splotches when I turned the TV back on is a mystery to me, although it is entirely possible that the coil has failed after eight years (I bought this TV new in late 1999).
I did not install the magnet permanently anywhere on the TV cabinet near the CRT, but returned the speaker to its shipping box when I saw that the color distortion had been eliminated.
I am still amazed as anything, however, that the CRT didn't implode or the TV wasn't damaged when it hit the floor of my apartment--face down, yet. I had visions of the CRT imploding and the set's own main PCB in pieces (almost the entire set is on one large PC board). The only things I can imagine that saved the TV from destruction are 1) that the set fell on a carpeted floor from a height of just over 2.5 feet (the stand the TV is on is only about 31 inches high), and 2) the set having fallen on a carpeted floor, as I just mentioned (my apartment has carpeted floors everywhere but in the bathroom). Had the floors in my place been hardwood (no carpeting) or the stand been much higher than 31 inches, the damage to the TV could have (and probably would have) been horrendous--smashed CRT, main PCB cracked in half or outright smashed to bits...
Old 09-20-2008, 03:33 PM
If the damage to the shadow mask was only minor, you could, in theory, magnetize it just the right way to correct the purity errors. If that's what happened, if you degauss it, the problem would come back. It's also possible that the shadow mask shifted slightly out of position, but snapped back into place.
I've seen a LOT of RCA TVs where the wires had fallen off the degaussing thermistor. The relay still works, but it won't degauss. When it was dropped, the thermistor could have broken free.
Old 09-20-2008, 05:50 PM
I too have seen many RCA's with thermistors that the wires had fallen off. It is a very common problem. You're shadow mask is probably OK if you were able to get a decent picture back on your set. I've seen sets where the shadow mask would be so bad out of line that all you'd see were rainbows on the screen.
Old 09-20-2008, 08:08 PM
C'mon, Jeff, fess up...You're really a Witch Doctor & you put on yr mask, danced around in front of it w/the magnets, & THAT'S what cured it...(grin)
Old 09-22-2008, 08:02 PM
Until the part where it fixed itself, I was going to guess that the yoke shifted slightly forward due to the fall.
Very misterious!
