Old 08-28-2008, 01:32 PM
Gronkus Gronkus is offline
Find of the Century! VBT 200 Mint in Box! *PICS*
Oh my do I feel lucky, check out what I found!
everything lights up! The vcr head was making a little noise wen it turned so I took it to a guy to have the head bearings oiled, now it doesnt turn tapes... He broke it! He said that the locks engaged that turns the tape and i need to have it unlocked???
No idea here, anyone good with these? Like i said it worked perfectly until i took it to this guy to have the head oiled. HELP!
Old 08-28-2008, 02:40 PM
Old 08-28-2008, 02:46 PM
im pretty sure. It played fine when i first got it, it was just getting noisy from time to time. Id love to get it fixed, i just dont know where to go.
Old 08-28-2008, 02:53 PM
waltchan waltchan is offline
Does the tape turn if you press down REW/FF? If so, then if the play mode doesn't turn, mostly likely the play idler next to the right reel will need to be cleaned. It's a complicated process.
Old 08-29-2008, 10:44 AM
kx250rider's Avatar
REAL TVs have TUBES!
VERY nice find!!!!!! My biggest thrill is getting something "as new in the box"!!! As said, keep oil FAR FAR away from VCRs. The only lubricating should be done with machine oil on a Q-tip, and only ONLY to melt the old, hardened existing moly grease where the factory used it on sliders, etc. One micro-drop of oil anywhere on the tape path will grab the tape, and often smash the heads out of the drum.
Charles
Old 08-29-2008, 11:20 AM
edison64's Avatar
edison64 edison64 is offline
THE A-1 WIRELESS MAN
Location: NW INDIANA THE MAPLE CITY LA PORTE (GO SLICERS)
Did you replace any belts yet?? all older vcr vtr units were famous for going through belts, I used to charge $35.00 for cleaning and new belts. MCM electronics used to sell kits for each brand, and the price uas usally about $5.00 Take the unit out of the case, ond use q-tips soaked in 91% percent isyprophyl alchol (not rubbing) any drug store or wal-mart about $1.50 clean all pulleys capstens and guides, and heads, use dry q-tips ro remove residue relubricate spairingly on head bearings and shafte and guides. i use ZOOM SPOUT TURBINE OIL, available from hardware store. replace with new belts and I bet you have success
RCA VICTOR and its dealers bring you......
Old 08-29-2008, 11:30 AM
Replacing the belts do work, but they are not guaranteed to work because FF/REW and Play must turn at the same time. If FF/REW makes the tape turn but play does not, then it's not the belts, but the play idler itself. I already fixed three units with this same, exact problem.
Old 08-29-2008, 07:30 PM
the play button will not push down. The VCR Worked great before i took it to the repair guy, he must have screwed up something. Anyone do repairs that i can send it to in FL?
Old 08-29-2008, 08:35 PM
I am no VCR expert by any means; but, it sounds like the "technician" that "repaired" yours done a lot more harm than good. I'd search the Internet and see if there was a repair center out there that specializes in video tape equipment repair. Don't fool with the local TV shops unless you can find one that's been in business for a long time and has some respect for older equipment. There was a service center in Jackson, MS called Delta Electronics that did electronic repair work for schools and other commercial interest. I'm not sure they are still in business as it's been about 15 years since I've been there.
That is a very nice find and it makes me sick that someone damaged this machine to this level.
Old 08-29-2008, 11:38 PM
oh believe me i was angry, the guy actually accused me of telling him it was broken, when all that was happening was a little noise when tapes were played. Every single function on the VCR worked perfectly too. I just hope some day I can find someone that will actually fix it so it operates perfectly again.
Old 08-29-2008, 11:42 PM
clydeselsor's Avatar
clydeselsor clydeselsor is offline
tubes and vinyl
Cool!
Old 08-30-2008, 12:39 AM
What amazes me is that someone could afford to spend US$800 or more on this VCR 30 years ago and just leave it in the box.
Old 08-30-2008, 12:29 PM
kx250rider's Avatar
I got a Sony SL7200 Betamax that way... A guy bought it because he heard that VCRs were the great new thing, but he just left it in the box until I got it from him for a really cheap price while I was repairing his TV! He also had an Aston-Martin in his garage that he bought and said he never drove because he didn't like how the side view mirror were. Go figure....
Charles
Old 08-30-2008, 01:16 PM
Check to see if the sensor lamp is still running. Do you see a light bulb on inside the VCR compartment when you turn on the unit? If not, then either your sensor lamp is broken or there's a loose connection. If play cannot be pushed down but you hear only a clunking sound, then it's the sensor lamp.
Old 08-30-2008, 01:24 PM
Mint in the box shows up quite often on eBay, but a brand new, factory-sealed, never opened is truly rare. I successfully bought four brand new, factory-sealed, never opened older VCRs so far:
1984 Sharp VC-489U 4-head Hi-Fi VCR (Sharp first 4-head Hi-Fi, $2,500 MSRP)
1989 Toshiba SV-F990 SVHS VCR (Toshiba's flagship SVHS, $3,000 MSRP)
Two 1991 Mitsubishi HS-U82 SVHS VCRs (Mitsubishi's flaaghip SVHS, $1,500 MSRP)
I am thinking of selling 1 of new in box Mitsubishi HS-U82 SVHS. PM me if interested and make your offer.
