Old 08-25-2008, 08:25 PM
rcaman's Avatar
rcaman rcaman is offline
weird crt tester on ebay
item 360081415420 it says it will check signal and anode who has tried one of these. i believe it will only check video signal from the chassis in a crude way.
Old 08-25-2008, 10:51 PM
Dave A's Avatar
Dave A Dave A is offline
Hickock Eye Chek
It looks to be the same thing as my Hickock Eye Chek. I scanned the instructions which explains what it does. Looks like it might be useful for a quick check for a few problems, but not much more. You clip it on the top of the set to make adjustments from the front. Never tried mine. Still NIB. The tube is a 6AF6G with a Sept. 1952 date code.
Dave A
Old 08-25-2008, 11:34 PM
kbmuri's Avatar
kbmuri kbmuri is offline
I have a very similar one called "Pix Eye". I googled it and found a pic of one on the web: http://vintage-electronics.com/photos/6740.jpg
I've used it 3 or 4 times and it does exactly what it says. Proves out your video and B+ and bias. Shows operation of brightness and contrast controls if your CRT is dead. It's a novelty to look at, but you can accomplish the same with an O'scope. Back in the day I guess the serviceman couldn't carry his O'scope with him. This thing, he could...
Do not attempt to adjust your set.
Old 08-26-2008, 01:48 AM
Quite intereting , I sent a email to the seller to se if they will ship to canada .
If so , I think I'll put a bid on it , First one I've seen ..
Old 08-26-2008, 10:46 AM
kbmuri's Avatar
Mine:
