15GP22 alert!
You know where and not mine;
http://cgi.ebay.com/1954-RCA-Victor-...d=p3286.c0.m14 From the seller; This 15GP22 does make a picture but unfortunately it is predominantly green. The tube does have a solid vacuum with very good getters. This would make a good candidate for a rebuild if the project becomes a reality. It is also a great display tube to fill a hole. The green was pretty bright and I did see a faint blue raster that was not converged but it also appears that the blue filament is out. It definitely is not as bright as the others. And seller has lot's of trim parts, etc from a parted out set it looks like. Dave A
“Once you eliminate the impossible...whatever remains, no matter how improbable, must be the truth." Sherlock Holmes. Last edited by Dave A; 05-06-2009 at 09:37 PM. |
