Old 04-07-2004, 11:30 PM
IF alignment help
Old 04-08-2004, 12:25 AM
Are you seeing the ghosted edges on an off air TV channel or cable channel? Or just the test generator? TV set IFs are tough to get right.
Be sure, if you do look at an off air TV station, that it is a decent ghost free signal. Feed from a directional rooftop antenna aimed at the TV station would be best.
If (this is a long shot) you have a good modern oscilloscope with a "TV video trigger" circuit, look at line 19 in the vertical interval right at the video detector. Some stations transmit what looks like a frequency chirp on that line. It's the ghost cancellation reference signal, and should have a reasonably flat response. Look at it using a VCR video output jack as a source to get an idea of what your antenna is doing to the signal. But use the off air signal directly from the antenna, not remodulated off the VCR when tweaking the IF. Try to remove peaks and valleys from the chirp, to make it look like what the VCR gets
I'm having roast rabbit for Easter dinner. .
Old 04-08-2004, 10:46 AM
Old 04-08-2004, 11:10 PM
Old 04-09-2004, 12:30 AM
kc8adu's Avatar
kc8adu kc8adu is offline
it is critical to have good if tubes in these sets.
i remember a portacolor with a strange agc problem that turned out to be a gassy if tube.
quick test for worn out tubes is to turn it off several seconds and turn back on.if it is washed out,weak color,ect and slowly returns to normal you got weak tubes.
email for more info
Old 04-09-2004, 12:38 AM
