Old 05-28-2008, 04:41 PM
Tony V's Avatar
Tony V Tony V is offline
Help with RCA CTC40
Hi Gang,
After messing with this RCA CTC40 combo of mine i came to the conclusion that it would probably be better to find another chassis for it than to fix the one thats in it. After checking it out it looks like either a power surge or lightning strike took it out as the tranny is fried along with most of the power supply. I checked the lytics and none were shorted so i dont think that caused it. It also took out the thermisters to the deguassing circuit. A month before this happened the color quit working so this wasnt the first problem with this chassis. I'm hoping that one of you might have a restorable or preferrably working chassis i could buy. I dont need the tuner, convergence assembly or yoke, just the chassis. I posted this a long time ago and thought i had a lead on one but the guy never came through. I figured i would try one more time and if no success then i would have no choice but to just part the set out. Any help would surely be appreciated.
Thanks,
Tony
