Old 04-03-2008, 09:24 PM
Electronics Accumulator
Nec Ct-2660a
I'm not even sure quite why I dragged this home. I found it out at the curb on my way home from work. It's an NEC model CT-2660A, 26" color TV, made in 1986. It has that wonderful 1980's particle-board cabinet, and it weighs quite a lot. It works, and has a pretty good picture. The onboard cable tuner seems to work pretty well, although I noticed a tiny bit of ghosting on higher channels. It produces a nice, bright picture, clear and with good color. The set receives stereo, and the internal speakers are... well..., they're TV speakers. The only complaint is that the top of the picture is a bit pulled in on the corners, and convergence at the upper corners is skewed. The rest of the screen is fine. I checked, and the yoke is secured properly, and does not appear to have shifted, all the rubber bits are glued in place. I don't want to go mucking with the convergence rings, since this seems like an electronic failure. Is this one of those sets that the TV techs remember? Common problem? I haven't investigated further, but I'm inclined to start replacing caps starting around the yoke connector and following the tracks back...
-Ian
Old 04-03-2008, 10:10 PM
I think the caps would be a good place to start. About the only NEC sets I used to find were branded Curtis Mathes. I did find a Kenwood with an NEC chassis in it. It seems like the ones I found either had bad flybacks, weak CRT's, or other weird problems that I gave up on.
Old 05-30-2008, 08:53 PM
Blast's Avatar
Blast Blast is offline
blast, blast...
-Ian
Does it change, or get worse/better the longer it's been on? If so, I would get a can of freeze spray and see if you can isolate the culprit. I think you're on the right track with caps.
Old 05-30-2008, 09:07 PM
