Old 03-14-2008, 04:58 AM
resistor color code NEED HELP .
Late last year I picked up a old Superior cross bar generator , I replaced the caps in it and I got the VHF section to work .
But the ocsillator for the bars is still not working , after lots of time spent messing around with it .
I have traced it down a resistor in the oscillator that it dead .
otherwise every thing checks out .
Any suggestions on this color code ?
It is a odd circuit ,there is JAN type 7193 wired up as a rectifier , and 2 , 954 acorn tubes , one as a transmitter , and the other one used as a oscillator to produce the bars .
Superior must have got a load military tubes .
the one end is silver , next to the yellow
To start of with black would be odd , would'nt it ? considering black is 0 on the first figure .
If I would start with yellow , it would be 470 ohm .
whats with the exrta colors ?
Old 03-14-2008, 05:09 AM
Electronics Accumulator
By "dead" do you mean open? Because that looks like a ceramic capacitor.
-Ian
Old 03-14-2008, 05:16 AM
Geek's Avatar
Geek Geek is offline
Nerd
Hi,
Looks like 470 ohms, 20% from the pic.
Cheers!
-= Gregg =-
Old 03-14-2008, 10:31 AM
Retro's right, that looks like a capacitor.
Old 03-14-2008, 10:39 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
looks more like a cap to me.
47pf 10% ??
Jordan
Old 03-14-2008, 11:27 AM
peaking coil? showing my ignorance
Old 03-14-2008, 11:35 AM
Old1625's Avatar
Old1625 Old1625 is offline
Here's another vote for capacitor.
Old 03-14-2008, 11:51 AM
avionic's Avatar
avionic avionic is offline
Eagle Keeper
Ya know, a schematic would be KEY here.Don't suppose you got a diagram for that old relic.Good Luck..Color code is inconsistent for a resistor.Its either a choke or a cap.Do you have a LCR meter.
RET USAF 1978-1998
Old 03-14-2008, 11:58 AM
kx250rider's Avatar
REAL TVs have TUBES!
A say peaking coil, or cap. Color code is the same as with resistors, but is applied differently.
Slightly off subject... There's a really bad saying that we probably all heard at one time, which helps you remember the color code... I can't remember the whole saying, but it starts "Bad Boys Rape (O_____) Young Girls.........". Does anyone remember the rest of the saying?
Charles
Old 03-14-2008, 12:03 PM
Steve K Steve K is offline
Charles:
I will PM the saying to you. I'm not sure if I can post it here.
Steve
Old 03-14-2008, 12:08 PM
Here's another version:
Bad Beer Rots Our Yellow Guts But Vodka Goes Well.
Old 03-14-2008, 12:28 PM
avionic's Avatar
Eagle Keeper
Bad Boys Ravage Our Young Girls But Violet Gives Willingly.... Can't help it, ex-GI.
RET USAF 1978-1998
Old 03-14-2008, 12:29 PM
blue_lateral's Avatar
Charles
But Violet Gives Willingly........
(edit.. oops, doubled...)
Old 03-14-2008, 12:43 PM
47pf 10% ??
Close - the code is:
Yellow Violet Red Black (silver dot)
Yellow = 4
Violet = 7
Red = 2 zeroes
Black = 20% tolerance
Silver dot = something to do with temperature rating
So, that's 4700pf, or .0047uf, +/- 20%.
A modern disc cap would be labelled 472.
And it's ceramic, so it's probably still good. Might as well try a sub while you've got it out though.
-Ian
Old 03-14-2008, 04:33 PM
I don't have a schematic for this thing
I was stupid and felt sorry for it sitting there on ebay , bid $9.99 for it .
thats where the trouble all started
There is only 1 other one that I have seen on the internet , I emailed the owner and he dosn't have a schematic either .
I should have got a Heathkit instead .
Who knows it might be a capacitor , I cannot get a reading off it at all with the VTVM , even at the RX1 meg setting . I have studied the circuit , and it seems alot like a hartley oscillator circuit , which would make it the part in question a resistor .
I tried a 470 ohm resistor in it late last night and had no better results
I have switched the tubes and still no better . I had a audio generator hooked up to the oscillator tube , when its connected to the grid the it doesn't produce bars too well , but when it's on the plate I was getting a nice bar pattern .
perhaps the next step is to try a cap
