Old 11-07-2007, 11:40 PM
Sencore VA48 TV analyzer
I picked up this Sencore VA48 TV analyzer on ebay a few months ago. It combines a pattern generator, tuner sub, various drive signals for tube and SS sets, flyback and yoke tester, etc. Everything appears to be working. There is a small quick set up book in the rear compartment; but, I don't have the main manual. I think I've got around $40 including shipping in it. A friend had a newer Sencore outfit that I think he had about $10K in. Has anyone had any experience with this piece of equipment and is this a good choice for vintage TV repair?
Old 11-08-2007, 01:08 AM
I have one of those as well, and I have the complete manual, I think. I bought mine and tuned it up several years ago, and now it has sat again for a while. Yes, it should have many uses in restoring antique TV sets, though I have never put mine to much use (I just got more involved in my old TV sets again after not doing much for years). I will look at mine in the next few days, and I will see what documents I have.
Old 11-08-2007, 01:29 AM
I also need to get some probes for mine. I'll admit that I've only used a multimeter and a scope to fix most things; but, the price seemed right on this piece. Most cheap modern TV's have about gotten to the point where if it can't be fixed with a multimeter; then, they aren't worth fixing. I also have an older stand alone Sencore flyback and yoke tester that will also check HV (if I had the probe). I've used it some on some newer flybacks with pretty good results.
Old 11-08-2007, 01:12 PM
kx250rider's Avatar
REAL TVs have TUBES!
I have one too. It comes in handy for subbing things like the tuner output to see if you have noise from your tuner, or if it's coming from downstream, and you can inject horizontal drive, vertical pulses, etc etc. It also has a color bar generator. Again, I don't use it often at all, but I like having it. I've never used the FBT and yoke ringer. I have a much newer Sencore LC-101 for that (and for full-working voltage cap leakage testing )
Charles
Old 11-17-2007, 08:06 PM
This is an excellent piece of equipment for servicing older TV's.
julian
Old 11-18-2007, 12:03 AM
Charles
Amen! I have the LC102 - how did we ever get by without these things?
I bought about 300 FP (can) caps from a company on eBay and sat for 3 nights checking them on my LC102. I found 3 that were bad - all 3 for dielectric absorption and 1 of the 3 also had bad ESR on two of the four sections. My only complaint is the keypad - I got bruised finger tips from holding the buttons down for some tests. I wish ESR was a no-hands test. For troubleshooting, I'll use my Bob Parker/Dick Smith ESR meter.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 11-18-2007, 12:53 PM
kx250rider's Avatar
I have an ESR meter that I use for quickly spotting dry electrolytics in newer equipment, but I haven't used it on cans in old TVs.
On the LC101, there's a goofy little spring rod thing that you put between the handle and the buttons for long-time forming. I couldn't believe that's what it was for, but it's in the book!!! Does the 102 also have it? I've never used it myself because I'd be afraid I'd forget, and that might result in a loud BANG!, and oily black capaci-fuzz all over the house.
Charles
Old 11-18-2007, 01:20 PM
Charles
Yes, my LC102 has the same, and the LC102 has a storage clip on the back for it as well. It's supposedly used only when reforming - it holds down the leakage button, and is placed between the handle and the keypad. If the leakage isn't acceptable after 10 seconds at full working voltage, I set the cap/can aside and reform it later. I've seen most caps pass after one reform cycle - if it doesn't, I send it to the trash. Sencore's Tech Tip 170 works for me. The DOD has a capacitor reforming whitepaper as well - had to use it when I was in the Navy on old "war stock" material that was sitting in warehouses. Essentially the same as bringing a set up on a variac...
Cheers
Old 01-13-2008, 05:51 PM
nasadowsk's Avatar
Damn does run fast…
Ok, I've got a VA48. It's a bit low on functionality because some circuit board under the main chassis has gone *poof*.
Anyone got a schematic on one of these things?
Old 02-07-2015, 12:12 AM
footlooseman footlooseman is offline
I recently got this unit. Did anyone ever find or upload a main manual?
Old 02-07-2015, 10:04 AM
I bought mine, maybe a year ago. I didn't get the main manual or the extra leads with it either.
Old 02-07-2015, 12:37 PM
WISCOJIM WISCOJIM is offline
Sonny has the reprints of the manual available on his website:
http://www.radiolaguy.com/Manuals/Sencore_Manuals.htm
Old 02-07-2015, 07:45 PM
Expensive!!
I've got the instruction manual and the simplified setup book - lemme spend a few days and I'll scan them to PDF and you can save yourselves some $$.
Cool side note - I found my dad's old notes on the GE AB/AC chassis, with the complete griplet list for adding jumper wires to fix all of the griplet issues, and his EC chassis notes - man, was that set a dog chassis.
look forward to a PM this week from me with the download URL for both manuals. Gonna take some time, but well worth saving my fellow VKers some cash.
I don't remember there being any special cables for the VA48 - just simple BNC or banana stuff. The trick is where to inject, what to inject, and what to observe on the CRT or the scope....
Cheers,
Old 02-07-2015, 08:46 PM
Can't get one from Sencore? They are based right where you are, in Sioux Falls. I have a buddy that was a Sencore traveling Rep (Rich Webb) - he used to call them for manuals, and they still have a copy-only archive library, as I understand it. They no longer reprint manuals for the general public, but may allow borrowing to copy...
Of course, you'd have to ask nicely, as Rich once had trouble getting an overlay for HIS company-issued LC53 - long story, but do not clean the vinyl overlays with nail-polish remover! Sencore gave him the run-around, and soon after he left the company, and went to work for RCA, later GE/RCA, as a service seminar host for several states.
Old 02-07-2015, 10:29 PM
Guys,
Second manual posted to same url/directory I PM'd you. It was easier to scan than I thought....
Hope it helps.
Cheers,
