Old 07-25-2007, 04:10 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
Sony Micro-TV 5-303W Blank, white raster.
I found a really nice looking little sony micro TV on epay for $10. It has some problems. There is no audio whatsoever, and the screen displays a blank raster no matter what channel the tuner is tuned to. Are there any common things to look for in this set that would cause a loss of signal after the tuner?
Old 07-25-2007, 04:18 PM
Mine had a buzz in the audio from the time I got it in the 80s. Eventually the audio went out entirely. I put off tackling it as I thought these would be a bear to work on, but they really are not. In fact, they are pretty easy-modular chassis. New caps will do wonders. That's all mine needed. I think it's pretty fun to recap little transistor stuff like this.
Old 07-25-2007, 04:40 PM
fsjonsey's Avatar
Mine has green poly film caps and ELNA electrolytics. Im guessing its the electrolytics that need to be replaced?
Old 07-26-2007, 12:07 PM
Yes, that is all I replaced. I only did the sections that were causing trouble. I also have a slightly newer model with UHF that had numerous problems; new electrolytics solved them all.
Old 07-29-2007, 04:48 PM
fsjonsey's Avatar
I've gone through pretty much all the electrolytics and still have nothing but a white raster with retrace lines. Are there any specific transistors that commonly fail in these sets? Im guessing the problem lies in a section common to both audio and video. Would anyone happen to have a sam's for this set?
Old 07-29-2007, 07:45 PM
I have scans of most of the Sam's folder. Let me know if you need them and I'll post them to my web space so you can download them.
Old 07-30-2007, 02:29 PM
Tony V's Avatar
Tony V Tony V is offline
Andy,
I would be interested in the scans also as i have two of them to get working.
Thanks,
Tony
Old 07-30-2007, 04:35 PM
http://wine-in-a-box.org/AK/
Let me know when you have them.
Old 07-30-2007, 10:52 PM
Tony V's Avatar
Thanks Andy! Its very much appreciated!
-Tony
