Old 05-29-2007, 09:13 AM
Richard D's Avatar
Richard D Richard D is offline
WORKING Indextron on ebay
This is the first one I have seen on auction that works!
http://cgi.ebay.com/ws/eBayISAPI.dll...ADME:B:SS:US:1
Old 05-29-2007, 09:32 AM
Hoo boy...That l'il salami will go for megabux...
Old 05-29-2007, 11:08 AM
kx250rider's Avatar
REAL TVs have TUBES!
I saw that this morning, and I put a $26 bid... This seller doesn't know what he/she has... They're in for a good surprise!
I can't bid near what it'll go for, but I am willing to go in the $200 range. I bet it goes for $400+, and probably to an overseas collector...
Charles
Old 05-29-2007, 01:56 PM
I didn't see any indication that it's currently working, just that they had used it once a long time ago and are assuming it works now?
A screenshot would be nice.
Old 05-29-2007, 08:12 PM
What is unusual/valuable about this TV? Are all 70's-90's small Sonys in high demand? I am curious, thanks.
Old 05-30-2007, 03:51 AM
waltchan waltchan is offline
Even though it works, it probably is going to fail soon. This TV has a very high failure rate. My dad had one, and it only worked for 1 year. His colleague also bought one, and it also worked only for 1 year. Both had no picture display after 1 year. I'm surprised that the one on eBay right now still works today. It's not worth putting your bid amount high, but it will not prevent me to bidding it.
Old 05-30-2007, 11:18 AM
zenith2134's Avatar
It appears to be a near-flat crt face too-- Why arent these long lived? IS it the tube or some oddball parts that are NLA? I know that the SCRS in my KV1712 are nowhere to be found so I'm hoping they hang on...
Old 05-30-2007, 01:10 PM
kx250rider's Avatar
This isn't a "regular" CRT. It's an Indextron, which is a version of field-sequencial color like the CBS system. Probably someone else can elaborate on this with more technical accuracy than I can. Basically, rather than having three beams hitting three pixels as happens in a regular CRT, there is only one cathode and one beam. It scans first one color field, then the second, then the third, in sequence. I think the horizontal oscillator in that set runs at 4,270 cps, not 15,750. The only other index-field sequencial TV from Sony is the FP60/62 portable projector which was made in the early 80s.
The collector value comes because they're incedibly rare, and are possibly Sony's worst TV blunder. They all failed, and I think I read that they were all recalled by Sony.
There are no known working ones to exist, that I know of. If this one works, it won't for long.
There is a value to any of the early Sony mini-color sets, but this one is a different animal indeed.
Charles
Old 05-30-2007, 10:57 PM
Dave A's Avatar
Dave A Dave A is offline
Actually, the Indextron is closer in history to the Philco Apple color tube from the mid-50's. Almost identical, but shrunk to a 3.7" size.
It is a single-gun beam passing over then unheard of vertical color stripes with a secondary trailing "index" beam which hits a secondary set of green phosphor stripes on the backside of the screen. They are set at every third stripe.
This secondary set of stripes is reflected to a photocell which tells the scan where the primary beam actually is at any given time and then modulates the primary beam to produce the proper information at that time.
Steve has a page of original Apple information here which also has a link to Chuck A's original Philco documents on the development of the Apple;
http://www.earlytelevision.org/apple_crt.html
AK member Jerome Halphen has a thread on a French site "Forum Radiofil" which is translated here. It shows a working Indextron with his descriptions of the circuits. The translation is a bit rough, but readable.
http://translate.google.com/translat...3DG%26pwst%3D1
I bought a dead Indextron a few weeks ago in ebay. When I got it, it was truely dead. A bit of Deoxit on a few connectors brought back a raster and for a few moments a picture with unsynchronized color. That went away and all I had was a shrunken white raster. Jerome was kind enough to email me the complete Sony service documents...in English! I gave it all to my local solid-state repair genius. He looked at me like I was nuts but took it anyway. Stay tuned.
Dave A
Old 05-30-2007, 11:54 PM
Thank you both for the notes and links. It is an interesting technology, especially the perfect convergence.
Old 05-31-2007, 02:34 AM
The one I saw had dozens of leaking caps. I suspect that this is the reason they were so unreliable. If so, recapping should be all that's needed to make a reliable indextron.
Old 05-31-2007, 04:39 AM
wiseguy wiseguy is offline
it does work,they sent me pics of it in operation,i tried to attach the pics to this posting,but they are too large,i have worked on the older fp-60's,but i have never seen one of the 4" ones at all
Old 05-31-2007, 05:19 AM
The thing I've never understood about the whole Indextron thing is WHY Sony bothered to fool w/it in the 1st place-They already HAD a world-beating CRT design-the Trinitron-why go to all the trouble to "re-invent the wheel" like that on something that, in retrospect, sounds like it was a VERY "iffy" technology at best ?
Old 05-31-2007, 12:24 PM
Bid is now up to $177. Who's willing to bid more?
Old 05-31-2007, 01:28 PM
I suspect they wanted something lighter, more durable, and smaller thean the Trinitron for a portable TV. Also, it would be immune to purity problems from being moved around. If not for LCDs, it may have become an important technology.
