Old 03-07-2007, 01:03 PM
Dan Schafer's Avatar
Dan Schafer Dan Schafer is offline
Danny in Cleveland
Magnavox 25Y105 chassis circa 1993
Hi All
I'm looking at my neighbor's TV set which is a Magnavox model RS2568 chassis # 25Y105-00AA. There is a little 2.5Amp B+ fuse that looks like a 1/2 watt resistor that opened. If I can fit it...will a glass pigtail of the same rating work? The horizontal output transistor is shorted (NTE 2353). The replacement tansistor is rather expensive so I don't want to pop the new one. Is there something that could have caused it to short. I have made that mistake before by not checking further. So any suggestions on what else to check for would be appreciated, if there is anyone out there who might be familiar with this chassis.
Thanks
Danny in Cleveland
Old 03-07-2007, 02:26 PM
Old 03-07-2007, 10:43 PM
Danny in Cleveland
Great Response!
Thanks
Danny in Cleveland
Old 03-08-2007, 12:07 AM
JCFitz JCFitz is offline
Also resolder the horizontal driver transformer.Bad solder connections on the legs of the transformer are common on those and it causes the transistor to fail.
Old 03-15-2007, 06:27 PM
rca2000's Avatar
rca2000 rca2000 is offline
You MUST replace the 100uf cap behind the fly!!
It is in the 130v. line, and will probably be "puffed up" on top. it WILL cause some bad problems on these sets. it is 100uf at 200volts or so, and is behind the flyback, and the regulator sink is in front of it.
And also, resolder the driver transformer and resistors of of it.
Old 04-14-2007, 11:21 AM
Danny in Cleveland
Magnavox 25Y105 Critical HV cap replacement
I finally got back to the repair of thid TV. I found a split opened and melted critical HV cap .01 2% @ 1.6KV ) original part marked 2KV) off the collector of the horiz. output transistor to ground. Anyone know where I can obtain a proper replacement or a suitable substitute?
Thanks
Danny in Cleveland
