Old 05-31-2024, 11:20 AM
JohnCT's Avatar
JohnCT JohnCT is offline
Originally Posted by pac.attack76 View Post
So I need to remove that fuse? Pin 5 is G1 right?
Yes on both.
When troubleshooting red plating, it's best to avoid running the circuit until the problem is solved, but if you need to run the circuit to make voltage and waveform measurements, then running without the cathode fuse is one way to prevent the plate from dissipating too many watts and weakening it. Removing the plate cap is another, but sometimes the lead drifts back to the tube and arcs.
Pin 5 is the first grid on most typical Zenith outputs like the 6LF6, but if you have a different output (not familiar with your model number), then you can look up the datasheet for the tube on line and identify the first grid.
Old 05-31-2024, 11:24 AM
pac.attack76's Avatar
Stuck in the past
Originally Posted by JohnCT View Post
Yes on both.
My horizontal out is 6LB6.
Genesis does what Nintendon't
Old 05-31-2024, 03:42 PM
JohnCT's Avatar
Then yes, pin 5 is G1. Should be a large negative voltage on pin 5 to ground - maybe -60 or so.
If that's missing, that's good. Loss of horiz drive is easier to troubleshoot than a secondary load issue.
Is there a schematic on line for your TV?
Old 05-31-2024, 04:23 PM
Stuck in the past
No idea. Put on 5 and ground. Got nothing. If I put it on right setting...
Old 05-31-2024, 06:56 PM
If you dont get the neg voltage on pin 5 of the 6LB6 either the
hoz osc is dead (6U10 ) or associated parts, OR the 6LB6 is dead
shorted.
BTW NEVER measure the plate of the 6LB6 OR the damper unless you like
fire trucks. Your meter will go up like a Tesla !
BTW #2 the HV regulator ( 6HS5 or 6HV5 ) must be matched with the
right damper tube. Look for tags on HV box or layout chart. Wrong
pair will work BUT not right & not for long.
Good you are taking it slow....
Zeno
Old 05-31-2024, 07:05 PM
Stuck in the past
shorted.
Zeno
Will a dead tube still light or no?
Old 05-31-2024, 10:13 PM
It's absolutely possible for a tube to have a good heater (part that lights) and a dead cathode (signal tubes and CRTs alike get this) or a short. Got a tube tester or know somebody with one?
Old 05-31-2024, 10:17 PM
Stuck in the past
Unfortunately no
Old 05-31-2024, 10:45 PM
Unfortunately no
You really should if you want to work on tube era sets. The alternative is to buy 2-3 examples of each tube (unless the seller has tested them there's no guarantee that they aren't used duds being sold) that you suspect is bad and try each of them... this is a bad approach on color horizontal sections as the 6LB6 is a $25-50 tube and 3 are more expensive than a basic tube tester.
Old 06-01-2024, 10:26 AM
Stuck in the past
I'll have to see if I can get one. Never thought I'd really need on but I've acquired more tube sets than expected.
Old 06-01-2024, 05:23 PM
We had good luck with the B&K. Just be sure it has the set-up book
& be modern, @ 1970 + REMEMBER checkers are NOT the final word.
Good tubes can check bad & bad tubes good.
Zeno
Old 06-01-2024, 11:06 PM
Stuck in the past
Zeno
I hear that. I'll see what I can do but not sure I can get one.
