Old 01-05-2006, 01:36 PM
kx250rider's Avatar
REAL TVs have TUBES!
Looking closely at the photo, yours is the inline CRT set. So the video driver board would be the one with the CRT socket on it... I think 9-121-xx. I'm really foggy on those by now, but I recall 9-121 as being it. There were 6 or 7 versions, so be sure to get the correct last two numbers if you get another board. Tap the board gently with a screwdriver handle while watching the screen, and see if it makes flashes or anything. There are 1 or 2 ceramic resistor networks on there that crack and cause intermittent video problems. Sometimes a cure is as easy as resoldering the connections on those networks at the board and also where their pins are soldered to the ceramic network itsself. Don't bother with that though if tapping the board does nothing.
Charles
