My Chromacolor II died
2 Attachment(s)
This is my bedroom set bought new in '79 or '80. It's a 19" table model with Space Command. Never been serviced. The other day my wife was watching it, said it made a loud crack or pop and the picture went white. Now it's a lit screen with a zig-zag white line.
I'm no technician and am reluctant to plunck down a alot of money to get it checked out. Does this look like an easy fix or is the tube shot? I guess this model gets a lot of respect from you TV guys, as I did some forum searches. I spend a lot of time on the vintage stereo forums, but am glad we have a TV section! These numbers are on the set: 19KC52 SK1989W |
Can you adjust brightness and contrast? Can you dim the picture with brightness control? If a tv station is tuned, can you hear sound? |
If there is sound its in the video module, if no sound the problem is most likely in the IF or gulp.....tuner.
A member here (jstout66 ?? ) has lots of chromacolor II boards. A PM with a board number may help you out. I would pull off the back and see if there is any obvious signs of electronic destruction (exploded cap, burn marks, etc..) and go from there. |
If you turn the color all the way up, do you see any color on the screen? It's possible that the CRT arced and took out something on the video output board.
I seem to remember an exploding electrolytic on the 9-88 luminance module in those... Take a look. As Andy says, see if you have any color, looks like a photograph negative with the color all the way up (Chromatic switch OFF). If you do, that makes it unlikely a picture tube problem. That set looks like the later type with the inline tube, so it could also be on the CRT socket module. The proper way would be to troubleshoot, as you are probably missing a voltage to the CRT. That would eliminate the guesswork. Even if you take it to a shop, they shouldn't charge much. Expect to pay a $25 bench fee to have it checked, and maybe $60 more or so to get it fixed unless it is the tube, or a tough troubleshoot.
Charles |
Thanks for the quick replies!
When first turned on, the screen turns shades of pink and green for a second or two, then settles into silver with the zig-zag lines. These are static when the cable box is off, they flicker back and forth when the box is on or tuned to an over-the-air station. None of the controls affect the picture-tint, color level, black level-screen stays colorless. There IS sound. I just took the back off to inspect. No visible damage, all 7 or 8 modules look OK, no exploded components or burn marks. |
Sounds like the video output board (not luminance) this controls the information to the guns. Perhaps the Y signal is missing?
I haven't had this problem with any chromacolors I've worked on.... |
jpdylon, which board would that be? They don't have names, only numbers. I found the 9-88 module, no damage.
Off the top of my head, i do not remember which board number. I have some service info for chromacolor IIs but I'm not sure if the board numbers are the same.
I'll have a look this evening. It would be the board that has the three yellow leads going to the picture tube. each yellow wire has a color representing the color of the gun its going to. |
I do have boards, so hollar if it is indeed a bad one, along with the module number needed.
Does somebody here has the schematics (as a pdf file)? |
There is no "brightness" controll, per se. Turning every knob on the control panel has no effect on the picture.
Gotta go to work now. We'll resume later. Bob |
from looking at the set, I think it may be one of the last Chroma 2's as it looks like the one with the inline tube. Zenith only made those for about a year. Off the top of my head I can't figure out which module it would be either. Once someone has the schematic let me know what board to look for. I don't think it would be the board that plugs into the picture tube from the symptoms given, but could be wrong.
What about the resistor pack on the video module that says "Caution--HOT". It seems like the later chromacolor II's used these and they seem to be a problem on slightly later models.
9-89 on most models, not sure about yours. |
| All times are GMT -5. The time now is 09:07 AM. |
